01-09-2017 10:29 AM
94 1234
tools
  1. B. Diddy's Avatar
    If the cache clear didn't do anything, see how things go in Safe Mode for a few hours.
    10-05-2016 12:11 PM
  2. hishaq96's Avatar
    Ok thanks I recharged the phone and battery looks stable again.
    S7 edge battery draining fast-1475691105839.jpgS7 edge battery draining fast-1475691110436.jpg
    B. Diddy likes this.
    10-05-2016 01:12 PM
  3. hishaq96's Avatar
    Hi I just wanted to know if anyone has returned the phone to Samsung due to battery life and high android system. I rang Samsung and they said next step is to get it inspected. As I have done the factory reset and has been no change.
    10-15-2016 07:40 AM
  4. JDGAFFLIN's Avatar
    Mines been fantastic. Battery life is great, no overheating issues, nothing.
    Hopefully you can get a replacement.
    10-15-2016 08:09 AM
  5. hishaq96's Avatar
    Thanks do you think its best if I do return? Also how much percentage is your Android system drain and how much SOT do you get?
    10-15-2016 08:19 AM
  6. KPMcClave's Avatar
    Search in this forum for Oculus/Gear VR issues. There's a thread dedicated to significant battery drain issues.. That *may* be your problem, and it's a lot easier to fix than having to send in your phone, FDR, or waiting on a replacment.
    10-15-2016 09:12 AM
  7. hishaq96's Avatar
    Once I factory reset the phone I have not reinstalled oculus app and the battery is still draining the same
    10-15-2016 09:55 AM
  8. underway99's Avatar
    I also had to disable the Gear service along with the app itself.
    KPMcClave likes this.
    10-15-2016 10:13 AM
  9. jgraves1107's Avatar
    Check your apps. One maybe on the internet constantly. I know for a while Facebook caused bad battery drain on a lot of devices.
    10-15-2016 10:16 AM
  10. hishaq96's Avatar
    Yesterday I deleted the Facebook app but no improvements
    10-15-2016 10:35 AM
  11. hishaq96's Avatar
    What's the average % that android system should drain?
    10-15-2016 10:36 AM
  12. mundo472's Avatar
    Update your Android System Webview. 54.0.2840.61. Turned the battery back to normal after the Sept update. (I think the radio is still a problem but I'm up to 12 hrs from 4, again)
    10-15-2016 06:58 PM
  13. hishaq96's Avatar
    Thanks yeah I did update that a few days ago
    10-15-2016 07:22 PM
  14. Maciualex's Avatar
    Hello all
    New to the forum. I have had this issue myself and I have read on plenty of android sites that in the last few days a lot of s7 users are having major battery issues.
    I found the cause to be the "oculus and Samsung VR" apps, once removed my phone stopped overheating and battery returned to normal.
    I also rebooted my phone, held power+home+volume up and noticed an update actually failed, and reinstalled the update.
    how did you reinstal the update. My s7 pushed an update and I did the update. During the update process it reached 30% and then restarted and began the update again from scratch. After I had the update android system drain is HUGE and cpu usage from that is almost constant. Could it be an failed first update the isue? And if so...how to solve it?
    11-04-2016 01:10 PM
  15. hishaq96's Avatar
    Hi i just wanted to know if i download this app will i get better battery life if so what is recommended to disable?
    12-06-2016 04:26 AM
  16. jejb's Avatar
    Don't know if it'll make it better, since I don't use it. But my battery life is crazy good w/o disabling lots of stuff, so I'm not going to mess with it.
    adayoff likes this.
    12-06-2016 05:25 AM
  17. clownin72's Avatar
    I haven't been able to tell much difference to be honest. Most ppl swear by it and others are on the fence
    12-06-2016 09:12 AM
  18. LeoRex's Avatar
    It's one of those things were you won't know until you try it. Samsung loads up so much crap in the phone, and a lot of the functions get buried in the system, that it is near impossible to figure out if that extra junk is weighing your phone down or not. About the only way to tell is to get yourself a good list of safe packages to disable and try them out for a few days to see if your battery consumption improves.
    And since everyone's usage is unique, you might see improvement, you might not...
    12-06-2016 09:18 AM
  19. popkurn611's Avatar
    No. I had it and got a new s7 edge without putting it on and no difference in battery life
    12-06-2016 10:10 AM
  20. hishaq96's Avatar
    Hello I just wanted a solution to the poor battery life I am getting as you can see in the screenshots.S7 edge battery draining fast-1481566326599.jpg
    12-12-2016 12:12 PM
  21. B. Diddy's Avatar
    The cell signal at the time of that screenshot doesn't look very good. Since poor signal can contribute to battery drain, it'd be helpful to see the cell signal strength throughout a battery charge cycle. You may have to install an app like GSam Battery Monitor to get that information.
    12-13-2016 02:06 AM
  22. hishaq96's Avatar
    Thanks but my poor signal doesn't show up on battery usage S7 edge battery draining fast-1481621578711.jpgS7 edge battery draining fast-1481621583244.jpgS7 edge battery draining fast-1481621586908.jpg
    12-13-2016 03:33 AM
  23. SupermanJon707's Avatar
    Thanks but my poor signal doesn't show up on battery usage Click image for larger version.
ID:	248003Click image for larger version.
ID:	248004Click image for larger version.
    It's under "Phone Radio" section of GSam
    12-13-2016 04:01 AM
  24. hishaq96's Avatar
    12-13-2016 04:16 AM
  25. jejb's Avatar
    What is under the App Usage in GSAM? Was the 12% drain in 55 minutes while the phone was idle? If so, I'd suspect a rouge app. You might also want to clear both caches.
    12-13-2016 07:52 AM
94 1234
  1. Snapchat flash to fast or quick
    Last Post: 09-02-2017, 08:56 AM
  2. Galaxy S6 Edge - Recent Apps button self pressing
    Last Post: 09-02-2017, 04:51 AM
  3. GSam Battery Monitor
    By bat1939_KM in forum Moto Z Force
    Last Post: 09-15-2016, 08:35 PM
  4. Replies: 1
    Last Post: 09-15-2016, 04:23 PM
  5. Replies: 0
    Last Post: 09-15-2016, 02:28 PM
