01-09-2017 10:29 AM
94 ... 234
tools
  1. hishaq96's Avatar
    I just did a factory reset see how it goes
    12-13-2016 09:38 AM
  2. B. Diddy's Avatar
    It's actually the line graph I'm looking for, that shows the cell signal superimposed on the battery level.
    12-13-2016 09:48 AM
  3. hishaq96's Avatar
    Hi I factory rested the phone but the battery still seems to be poor is there any other solution. Also why is device idle draining the battery?S7 edge battery draining fast-1482098349713.jpgS7 edge battery draining fast-1482098356636.jpg
    12-18-2016 03:59 PM
  4. Bichon-Fan's Avatar
    It looks like your cell reception is very low. That will take its toll on your battery.
    Dngrsone likes this.
    12-18-2016 04:03 PM
  5. hishaq96's Avatar
    I was on a different network previously which had good signal but the battery life on this phone was still poor
    12-18-2016 04:30 PM
  6. jeetu4444's Avatar
    Make sure nfc,background wifi scanning is off and brightness on auto...
    12-18-2016 05:14 PM
  7. hishaq96's Avatar
    That is exactly what I do as I never use Bluetooth or nfc so they are always off and i keep my brightness always on auto
    12-18-2016 05:57 PM
  8. anon(9408097)'s Avatar
    SOT : % consumed
    1 hour 30 minutes : 30% down
    3 hours : 60% down
    4 hours 30 minutes : 90% down
    4 hours 45 minutes: 100% down
    4 hours 45 minutes on average. What more do you want? And what are you expecting?
    12-19-2016 03:42 AM
  9. Paradroid01's Avatar
    I'd say, turn auto brightness off for better battery life.
    12-19-2016 04:53 AM
  10. tshirttan408's Avatar
    What sorted my battery life out was having location set to gps only, and switching it to cell and gps only if I needed to use google maps
    12-19-2016 07:50 AM
  11. hishaq96's Avatar
    [IMG][/IMG]The cell signal at the time of that screenshot doesn't look very good. Since poor signal can contribute to battery drain, it'd be helpful to see the cell signal strength throughout a battery charge cycle. You may have to install an app like GSam Battery Monitor to get that information.
    S7 edge battery draining fast-1483106589618.jpg does this show that the poor signal is indicating the battery drain
    12-30-2016 08:03 AM
  12. hishaq96's Avatar
    Hi i my battery drains all the time and wanted to know is it due to poor signal.
    12-30-2016 08:08 AM
  13. ZOMMBIE1's Avatar
    A poor signal definitely drains battery. From the looks of it you do have a poor signal from your cell company
    12-30-2016 08:53 AM
  14. Soundman72's Avatar
    Yes poor signal does affect battery life as your phone will hunt from for a stronger signal which will affect battery life
    12-30-2016 08:59 AM
  15. trucksmoveamerica#AC's Avatar
    Yes poor battery signal will effect battery.
    Why did you start a new thread, you were discussing this in your other post.
    12-30-2016 09:16 AM
  16. B. Diddy's Avatar
    The signal's not great, although it's not constantly bad either.
    I noticed from your first post that you had 2 hrs 9 min of screen on time, with the battery down to 44%. This means you were on track for about 4 hrs of total screen on time for a full battery charge -- that's not all that bad. The constant mediocre cell signal you have is probably enough to explain that whole battery picture.
    12-30-2016 12:46 PM
  17. Almeuit's Avatar
    Merged all your threads since they were on the same topic.
    12-30-2016 01:07 PM
  18. hishaq96's Avatar
    I'm getting even poor battery life today using greenify tooS7 edge battery draining fast-1483965494387.jpgS7 edge battery draining fast-1483965498937.jpg
    01-09-2017 06:38 AM
  19. B. Diddy's Avatar
    I still think your battery life isn't that unusual, given your usage patterns, estimated screen-on time, and signal issues.
    01-09-2017 10:29 AM
94 ... 234
  1. Snapchat flash to fast or quick
    Last Post: 09-02-2017, 08:56 AM
  2. Galaxy S6 Edge - Recent Apps button self pressing
    Last Post: 09-02-2017, 04:51 AM
  3. GSam Battery Monitor
    By bat1939_KM in forum Moto Z Force
    Last Post: 09-15-2016, 08:35 PM
  4. Replies: 1
    Last Post: 09-15-2016, 04:23 PM
  5. Replies: 0
    Last Post: 09-15-2016, 02:28 PM
