1. fordhamtroll's Avatar
    Hello fellow AC people. Having issues with Greenfiy on my S7 edge. As the title indicates, I can't get it to auto-hibernate any apps. Anyone have any ideas/suggestions? Thanks!
    09-16-2016 10:07 AM
  2. gozirra's Avatar
    In Settings, Lock Screen & Security, Other Security Settings, Phone Administrators, is Greenify "On"? I don't use Greenify anymore but I seem to remember it needing this additional permission.
    09-16-2016 10:43 AM
  3. fordhamtroll's Avatar
    Yes, it's turned on but no matter what I try, it will not automatically hibernate any apps.
    09-16-2016 12:24 PM
  4. fordhamtroll's Avatar
    Actually, I don't see a phone administrators. I see Device Administrators. I turned it on but it still doesn't auto-hibernate apps.
    09-16-2016 12:29 PM
  5. scorpiodsu's Avatar
    I stopped using it because of this. Not sure if it's because the phone isn't rooted or what greenify just isn't the same and not needed as it was before.
    09-16-2016 12:40 PM
  6. chanchan05's Avatar
    Auto hibernate on an unrooted device needs an unsecure lockscreen (no pin or pattern), apart from administrator level permission.
    KPMcClave likes this.
    09-16-2016 02:22 PM
  7. fordhamtroll's Avatar
    My screen is locked via fingerprint. Phone is not rooted. Since when doesn't greenify not work and/or auto hibernate apps on an unrooted phone?
    09-19-2016 09:39 AM
  8. MetalKore's Avatar
    I recently started using Greenify, and I am experiencing a similar issue. I am able to auto-hibernate apps, however, I do have to "re-hibernate" several times throughout the day.
    09-19-2016 01:56 PM
  9. chanchan05's Avatar
    Having a fingerprint lock means you have a backup PIN or pattern. Not sure since when, but it's written right in the app:
    09-19-2016 04:34 PM
  1. anyone having problems with their S-pen not working correctly with note 7?
    By Amirofthedesert in forum Samsung Galaxy Note 7
    Last Post: 09-19-2016, 01:53 PM
  2. Why I my app post is not getting published?
    By Jainutechnologies in forum Android Apps
    Last Post: 09-18-2016, 11:04 PM
  3. Note 7 DRAW OVER APPS
    Last Post: 09-16-2016, 04:46 PM
  4. How do I move apps and/or data to the SD card?
    Last Post: 09-16-2016, 10:09 AM
  5. Productivity apps do not run in background
    Last Post: 09-16-2016, 09:42 AM
