1. bandofbrothers2112's Avatar
    Hello,
    Hi,
    MediaServer is showing in my Battety usage at 24%
    What would be running to use that ?
    09-16-2016 02:14 PM
  2. SpookDroid's Avatar
    Anything that accesses media from your phone, like a local media music player. It also 'shoots up' if there's something wrong with your SD Card (corrupt files, damaged card, etc.) Try removing that and see if it goes down (if it does, it might be time to either check your files or replace the card).
    09-16-2016 02:20 PM
  3. bandofbrothers2112's Avatar
    Thanks for your reply.
    On another forum some say it's Google Chrome.
    In my Battery Stats the % is the same for Chrome and Media Server !
    09-16-2016 02:56 PM
  4. wirelessgal's Avatar
    I have the same issue but only when I use Power Amp. It shows in my battery usage around 33%. I have videos and pictures in my SD CARD but mediaserver is fine. It's not draining my battery though. Should I be concerned?
    Thanks.
    09-17-2016 08:27 AM
  5. BartRom's Avatar
    I also have this issue. I noticed it's caused by playing music. Because of this, music playback is using a lot of battery IMO. Is it a bug?
    09-22-2016 02:26 AM
  1. Samsung, VZW and Sam's Club - All Clueless
    By billykac in forum Samsung Galaxy Note 7
    Last Post: 09-22-2016, 07:51 AM
  2. cell phone won't work with intercom in my building
    Last Post: 09-22-2016, 04:59 AM
  3. FB Group Notifications in Notification Panel
    Last Post: 09-16-2016, 02:13 PM
  4. Galaxy S5 Extra Batteries Protection?
    Last Post: 09-16-2016, 01:23 PM
  5. Replies: 1
    Last Post: 09-16-2016, 01:20 PM
