1. Conor78's Avatar
    Put my phone on the charger and when I woke this morning it was in safe mode and folders has disappeared from my home screen.. I can't remember which ones try are...is there a way to restore them??
    Thanks
    09-17-2016 02:00 AM
  2. B. Diddy's Avatar
    If you're truly in Safe Mode, then powering off and then powering back on again should boot you back into normal mode. Does that happen?
    Or are you in Factory Mode, which looks more like this?
    09-18-2016 02:48 AM
  1. Replies: 9
    Last Post: 09-20-2016, 03:27 PM
  2. How to add a folder to the photo gallery on my Blu pure xl
    Last Post: 09-16-2016, 08:05 PM
