1. cbqgal's Avatar
    Hi,
    I went to the Samsung website to get updates on software for my galaxy S7 Edge phone which I purchased in March.
    I had to type in the model# which is SM-G935A . But they listed 3 versions of that # ………………
    SM-G935AZDAATT ,
    SM-G935AZKAATT ,
    SM-G935AZSAATT
    How do I find out which applies to my phone ? AT&T is my provider. I can’t find any listing of these extended model #’s in the “About” section of my phone.
    I went to the Samsung website because after clicking on "Software Update", my security software was not getting updated.
    Thanks
    09-17-2016 02:05 AM
  2. underway99's Avatar
    A Google search shows that those appear to be the different color options.
    SM-G935AZDAATT is gold
    SM-G935AZKAATT is black
    SM-G935AZSAATT is silver
    I cannot say with absolute certainty that they use the same software, but it is extremely likely that they do.
    Regarding your updates, I'd expect that since you have a carrier-branded device, your updates will come from AT&T, not directly from Samsung. Sometimes you have to force the device to do the update check too.
    09-17-2016 08:41 AM
  1. how do I keep rejected call from going to voice mail?
    Last Post: 09-26-2017, 12:34 PM
  2. i have galaxy grand prime and i have a app called Zedge
    By karen volker in forum Ask a Question
    Last Post: 09-23-2016, 02:47 PM
  3. is this the rite version for my samsung galaxy 5
    By Whatleys_Wifey00 in forum Android Apps
    Last Post: 09-17-2016, 12:26 AM
  4. Samsung Website to Check IMEI Number for Recall
    By onthehunt in forum Samsung Galaxy Note 7
    Last Post: 09-17-2016, 12:15 AM
