Is there any word on a the September Security Patch and if it'll fix the Android System usage bug? The Android System is using a ton of my battery in the August patch and before that I was ending the day off with about 30-50% battery now I'm ending it off with 10-30% which is significantly worse. The last few patches have been bad for battery life for me. Anyone else getting bad battery life?
