09-23-2016 03:16 PM
32 12
tools
  1. bchandler02's Avatar
    I have this one, with a case. Works great.
    https://www.amazon.com/gp/product/B0...cUvbUpU5439209
    09-22-2016 12:16 PM
  2. JDfan3340's Avatar
    So I got this one.........
    Samsung Galaxy S7 Edge Screen Protector Case Friendly ArmorSuit Militaryshi | eBay
    It's relatively easy to put on. I would definitely watch the video first. But it's on, and if you mess it up, you can redo it. It looks pretty good. Not as good as nothing, obviously. But being a Firefighter, I just wasn't comfortable with nothing on it. I went to a training tonight that was pretty intense, and had the phone in my gear pocket. I had a Speck case on it, and it did great!
    09-22-2016 09:47 PM
  3. maf113's Avatar
    I'm a firefighter also. So far the only screen protector I've found that works is the bodyguardz hd. It's the $25 one from att. Thanks I use that and the zizo bolt case off Amazon when I'm running calls.
    That is what my wife has on her S7E and it works with her cases. We are on Verizon and had to go to att to get one. I had the store install it. It does not go edge to edge but does cover most of the screen including the curved side. The protector had a curve on the edges so fits nice.
    09-22-2016 10:05 PM
  4. Tower72's Avatar
    https://www.amazon.com/gp/product/B0...cUvbUpU5440826
    I have this. I have heard nothing but bad things about tempered glass ones, plus using a case with anything that covers all the corners will cause issues. This one, while being a "film", works great with ever case I used considering the corners are trimmed off, allowing any case with a lip to work just fine.
    09-23-2016 12:33 AM
  5. JDfan3340's Avatar
    WHHHHHHHHHHHHHHHHHHHHHHHHHHHHHYYYYYYYYYYYYY must there always be ONE piece of fuzz that gets stuck under my screen protector!!!
    09-23-2016 02:11 PM
  6. Burton79's Avatar
    Following just to see if anyone has solid suggestions. I was at best buy and they said their geek squad can just make one butbitbsounds like plastic and didn't really inspired confidence.
    09-23-2016 02:40 PM
  7. JDfan3340's Avatar
    Now I'm trying one from bestskinsever.com. It went on the same way as the last one, but seems clearer than that one was.
    09-23-2016 03:16 PM
32 12
  1. Note 7 Fast Charging Not Working
    By Bartone in forum Samsung Galaxy Note 7
    Last Post: 10-02-2016, 07:31 AM
  2. Why can't I unlock lg G STYLO?
    Last Post: 09-19-2016, 08:11 PM
  3. Replies: 1
    Last Post: 09-19-2016, 12:56 PM
  4. can't update Google or other programs
    By graytoni in forum General Help and How To
    Last Post: 09-19-2016, 12:37 PM
  5. Replies: 1
    Last Post: 09-19-2016, 11:33 AM
