1. bsteppuhn's Avatar
    I dont even have a charger plugged in
    Attached Thumbnails Incompatible Charger message while not even charging.-screenshot_20160919-163104.jpg
    09-19-2016 05:36 PM
  2. SpookDroid's Avatar
    Have you rebooted? My guess is that the USB port or charging circuit has been damaged. Try cleaning the port with a soft toothbrush or CAREFULLY with compressed air (while the phone is off).
    09-19-2016 06:06 PM
  3. bsteppuhn's Avatar
    I have rebooted. Now states water in port. Hasnt even been in water. I really love this phone :-(
    09-19-2016 07:54 PM
  4. bsteppuhn's Avatar
    I can charge wireless thank god but I only have one and a slow one nit a near fast one.
    09-19-2016 07:55 PM
  5. SpookDroid's Avatar
    Doesn't mean it's water, it might be just dust or sand. Still try to clean out the port with a brush and if that doesn't help and if the message is popping up without anything being connected to it, then I'd suggest taking it in for repair as it's most likely the charging port.
    09-20-2016 12:04 PM
  1. G4 not recognizing USB cables
    By Margo Thompson in forum Moto G
    Last Post: 09-21-2016, 12:02 PM
  2. Replies: 1
    Last Post: 09-20-2016, 01:19 AM
  3. Samsung s7 edge cracked during charging
    By DWhitfield84 in forum Samsung Galaxy S7 edge
    Last Post: 09-19-2016, 08:42 PM
  4. my google desktop calendar will not sync with Samsung S7
    Last Post: 09-19-2016, 04:40 PM
  5. Why is my phone taking 3 hours to charge?
    Last Post: 09-19-2016, 02:38 PM
