1. YMarkY's Avatar
    I'd like to put a dock like this on my Galaxy Edge S7. Can anyone help with this? Not sure if it is just a widget or KLWP, or something else.
    Can't get a reply from Google+ group.
    Thanks
    09-20-2016 12:32 AM
  2. chanchan05's Avatar
    You can do that with Nova Prime. Just activate Labs feature for putting widgets on the dock and slap a clock widget on it.
    09-20-2016 12:34 AM
  3. YMarkY's Avatar
    I activated the Labs feature on Nova Prime, but there is no such option to put widgets on the dock. I'm using the latest Nova Prime beta.
    09-20-2016 01:01 AM
  4. chanchan05's Avatar
    I just tried it. You can just drag thr widget to the dock. It's graduated from the labs already.
    09-20-2016 01:24 AM
  5. MrsWaffles's Avatar
    Where do you find the labs feature?
    09-20-2016 01:48 AM
  6. YMarkY's Avatar
    Go into settings for Nova Launcher and hold down the volume button.
    09-20-2016 01:54 AM
  7. YMarkY's Avatar
    I got a widget placed on the dock. Thanks a bunch.
    09-20-2016 01:56 AM
  1. Samsung S7 Docking station, can anyone recommend?
    By atomarchio in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 10-14-2016, 06:31 AM
  2. Replies: 2
    Last Post: 08-25-2016, 08:53 AM
  3. Looking for a note 7 dock with type C input
    By angiebugg in forum Samsung Galaxy Note 7
    Last Post: 08-23-2016, 06:27 PM
  4. Replies: 0
    Last Post: 08-21-2016, 03:46 PM
  5. re: the docking station that i got for samsung galaxy tab 2-10.1
    By reble in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-15-2016, 04:42 AM
