1. bialy's Avatar
    Does the s7e have a blue light filter for night time viewing?
    How different than the Note7?
    09-20-2016 12:38 AM
  2. victoryrules8's Avatar
    Unfortunately it doesn't yet... Hopefully with an update from Samsung soon we can see this built in feature on the s7 edge.
    Gray Area likes this.
    09-20-2016 01:19 AM
  3. chanchan05's Avatar
    You can download one from the store while waiting for an update.
    09-20-2016 01:30 AM
  4. bialy's Avatar
    What's its name? Can you just set it so that is automatically goes into blue light night mode from say 7pm to 7am and not worry about it after that?
    09-20-2016 09:54 PM
  5. chanchan05's Avatar
    Yes. Well I think it does. I have a paid version so that feature is available. Can't remember if it's available for the free version. It's called Twilight. Has a red circular icon with a setting sun drawing.
    09-20-2016 09:59 PM
  6. bialy's Avatar
    Ok, you want want that feature to be seamless and free. Do you notice the filter and how does it seem to view screen with it? Thanks.
    09-20-2016 10:02 PM
  7. chanchan05's Avatar
    You can adjust the intensity of the filter. Well like any blue screen filter, the screen will have a tinge of yellow to red depending on how intense the filter is set. Then you can set exceptions, like gallery (for color correct pictures), where the app will disable.
    09-20-2016 10:39 PM
  8. anon(871934)'s Avatar
    Twilight is a good app. The automatic sunset/sunrise settings is a paid feature. The scheduling at fixed on/off times is free (I think). You can even block the notification panel for Twilight so it is completely set and forget like the Note 7 feature.
    09-21-2016 09:56 AM
  9. Gray Area's Avatar
    Thanks for this, 1 of the features I missed from the note 7. I do like Samsung's implementation of it better because it only applies to white colors, where as this app tints everything including black. Nevertheless it works very well. Does it drain alot of battery?
    09-22-2016 09:17 PM
  10. chanchan05's Avatar
    Not that I noticed.
    09-22-2016 09:22 PM
  11. bialy's Avatar
    Does the filter simply come on and off, Or does it gradually come on and gradually come off??
    09-23-2016 12:14 AM
  12. Gray Area's Avatar
    From what I've noticed it just comes on, not like Samsung's implementation, where it's gradual based on time and light situations. But I've only had it for 1 night so I'll see this evening.
    09-23-2016 05:54 AM
  13. chanchan05's Avatar
    It can do gradual. Tap the 3 dots on the bottom of the screen (you may have to scroll down) and get to 'transition time' to adjust how fast it reaches the full intensity that you set.
    09-23-2016 06:37 AM
  14. GoldenWarr's Avatar
    The sunset/sunrise setting is included for free. The pro version gives you access to more than 2 profiles as well as sunset/sunrise offset and transition time.
    09-23-2016 07:12 AM
  1. Replies: 3
    Last Post: 09-30-2016, 07:04 PM
  2. Display lights up. How to shut down?
    Last Post: 09-22-2016, 03:43 PM
  3. Replies: 1
    Last Post: 09-19-2016, 11:22 AM
  4. Moto G3 Notification LED Light ON
    Last Post: 09-19-2016, 02:32 AM
  5. Replies: 0
    Last Post: 09-18-2016, 09:36 AM
