1. Whitetulips9's Avatar
    On the Samsung Galaxy S7 Edge, is there a way to keep the keyboard on symbols. I used to be able to put multiple exclamation marks in a row, but not it automatically goes back to regular keyboard after pressing one symbol. Very frustrating!
    10-02-2016 05:31 AM
  2. srkmagnus's Avatar
    It's been a while since I've used a Galaxy device, and don't know if it's possible. However, you can check through the keyboard settings to see if a setting allows you to keep the symbols screen up longer. Alternatively, you can likely long press on another letter/number to quickly access symbols. If still nothing works then consider an alternative keyboard. Not the ideal solution, but something to consider in the interim.
    10-02-2016 01:11 PM
  1. Lenovo A806 Bluetooth & keyboard not working at the same time
    Last Post: 10-02-2016, 12:00 PM
  2. How to create a movable and resizable keyboard on android
    Last Post: 10-01-2016, 10:45 PM
  3. how to bypass set up on htcd100l verizon
    Last Post: 10-01-2016, 10:38 PM
  4. the keyboard wont pop up on my android
    Last Post: 10-01-2016, 08:45 PM
  5. No keyboard option Google voice typing can't disable
    Last Post: 10-01-2016, 01:32 PM
