Carrier unlocked???
Rumblee1
Trusted Member
Nov 3, 2012
1,521
3
38
Back in march, when the edge first came out, I bought one from Verizon. I know that Verizon runs on cdma. But a frien of mine told me that all verizon phones are sold unlocked. Does that mean this edge will run on all networks eith their sim card installed? Even if it's a gsm network?
tgp
Trusted Member
Nov 15, 2011
761
Yes, it will. You may not get LTE depending on what band(s) are used, but otherwise it should work. The only caveat that I know of is that some low cost prepaid Verizon phones, such as the Moto E, are locked until you activate them on a Verizon plan. Once activated, they will be SIM unlocked as well.
sandersc
