1. Rumblee1's Avatar
    Back in march, when the edge first came out, I bought one from Verizon. I know that Verizon runs on cdma. But a frien of mine told me that all verizon phones are sold unlocked. Does that mean this edge will run on all networks eith their sim card installed? Even if it's a gsm network?
    10-03-2016 06:36 AM
  2. tgp's Avatar
    Yes, it will. You may not get LTE depending on what band(s) are used, but otherwise it should work. The only caveat that I know of is that some low cost prepaid Verizon phones, such as the Moto E, are locked until you activate them on a Verizon plan. Once activated, they will be SIM unlocked as well.
    10-03-2016 06:56 AM
  1. what about u dates if my phone is unlocked
    By mikey1273 in forum LG G5
    Last Post: 10-07-2016, 08:27 AM
  2. Replies: 3
    Last Post: 10-04-2016, 09:08 AM
  3. Replies: 1
    Last Post: 10-03-2016, 01:34 AM
  4. what company should I use to unlock a straightalk phone?
    Last Post: 10-02-2016, 04:35 PM
  5. Replies: 1
    Last Post: 10-02-2016, 11:29 AM
