1. S1eep1ess's Avatar
    I have unlimited everything on my phone. I cancelled my home WiFi. My phone service is just as fast and works just as good as any WiFi.
    Now because of the 100 mb block limit. I can't install any updates over my phone.
    Is there a way I can bypass this? Maybe with an apk file extension. My phone isn't rooted. I can't disable Google play without it reinstalling it's self.
    I don't like using public WiFi servers.
    10-04-2016 11:58 AM
  2. thisbearisdrunk's Avatar
    i guess u have set limit for data usage maybe try this
    go to settings and open up "data usage" and u should see an option "Set mobile data limit" try switching it off
    10-04-2016 12:13 PM
  3. Rukbat's Avatar
    That ay be one of the "invisible" limits to your unlimited - you can use as much data as you like, but you can't use any practical amount. Most carriers don't limit the block size. (I've downloaded 4GB ROMs.)
    10-04-2016 12:38 PM
  4. S1eep1ess's Avatar
    From what I have learned from researching my problem. It's a cap not only on samsung but for IPhones as well. Any service provider update that reaches over 100 mb has to be done on a WiFi connection. That's why I was wondering if I could install an apk version to bypass the block and be able to update without using a public WiFi server..
    10-05-2016 05:13 AM
  5. S1eep1ess's Avatar
    Yeah I reset my mobile data usage limit. That didn't work either. Like I said it's built in. I called T-Mobile and Samsung each said it's the others problem. Thanks for y'alls help.
    10-05-2016 05:16 AM
  6. reddragon79's Avatar
    Wow that's really odd I'm on tmobile I haven't seen any kinda cap on anything.
    10-05-2016 06:42 AM
  7. IAmSixNine's Avatar
    Now i wish i would have paid more attetion Monday when i had a game update and it was over 100 megs, i was prompted to use WiFi or Proceed to do it over cellular. This was through the play store. I thought the update was 110 or 115 megs.
    Hopefully it will happen again soon and ill try to remember to take a screen shot.
    10-05-2016 10:57 AM
  8. reddragon79's Avatar
    Are u on the new tmobile one or u on the old tmobile I'm under the old tmobile unlimited plan
    10-05-2016 11:39 AM
  9. IAmSixNine's Avatar
    I have the 4 lines $150 deal for unlimited data, 14gb tethering per line. So old TMo unlimited plan.
    reddragon79 likes this.
    10-05-2016 04:00 PM
  10. IAmSixNine's Avatar
    Thought i had it last night. One of my games had an update and it prompted me to use wifi or proceed with cellular, but it was only 94 megs.
    10-06-2016 07:46 AM
  1. Group Text Limit
    By ITworksLLC in forum Samsung Galaxy S7 edge
    Last Post: 10-06-2016, 06:37 AM
  2. Accidentally blocked an email sender on my Gear Fit2
    Last Post: 10-04-2016, 11:39 AM
  3. What is the size limit reached on Driod for text messages
    Last Post: 10-03-2016, 04:21 PM
  4. Replies: 1
    Last Post: 10-02-2016, 05:39 PM
  5. Android file size limit
    Last Post: 10-02-2016, 05:17 PM
