So, this morning it started on the re-start, re-start kick. I decided to try the factory reset – it worked again, I reset all the data from the Samsung uplink, and then my beautiful dual SIM S7 edge keeled over and comprehensively died. No amount of magic button presses will wake it up again. Samsung UK won’t touch it as it was a far east import (though a totally genuine phone) and the company I got it from is no longer trading. The only think Samsung UK can suggest is that is re-flashed from a private UK repair store, but I am not certain that even this can be done if you can’t get it to come to life and boot into any form of menu – does anyone know? At the moment its only sign of life is a red LED top left of the unit is on. I’ve tried button combination going to get it back and been talked through by the Samsung lady on the phone. It’s DEAD.
So now I’ve got to go back to two phones – one business and one personal as you can’t legitimately buy a Dual SIM phone anywhere in the UK it seems (I’ve been researching this). Why, oh Why does the rest of the world get dual sim capability, but not the UK. The annoying thing is that dual sims are supported – the Samsung lady was surprised, but mine has been taking android updates, taking calls on both sims and behaving as it should for a good bit of time before it failed.
Wake up the UK and let us buy Dual sim phones!!
