1. Est_XCIV's Avatar
    I have recently been using Greenfiy with Agressive Doze Mode which puts the phone in doze in a few minutes rather than an hour. Also enabled Doze on-the-go Mode which disables the motion/accelerometer which takes the phone out of the doze state. In order to enable that feature you have to use ADB and your phone does not have to be rooted.
    Link:
    https://greenify.uservoice.com/knowl...-some-features
    10-06-2016 10:39 AM
  2. Est_XCIV's Avatar
    Almost 20 hours without charging.
    10-06-2016 10:41 AM
  3. tshirttan408's Avatar
    yeah I've done the exact same thing recently and am noticing significant improvements!
    10-06-2016 11:41 AM
  4. sLithery's Avatar
    Do I have to use the Android 7.0 command it says "non-root" (my phone isn't rooted) or do I have to use "device with Doze disabled"? I'm not sure if the second one works for me since my phone isn't rooted(it does not mention root).
    And my second question does the AoD function still work?
    Thanks
    10-06-2016 05:27 PM
  5. Gray Area's Avatar
    Link:
    Couldn't get this to work, been using greenify for yrs but never tried this, and when I followed the directions my pc isn't doing anything. Feels like a step is missing.
    10-06-2016 05:40 PM
  6. chanchan05's Avatar
    What do you mean your PC isn't doing anything? Have you installed ADB and entered the commands? If you did when you open greenify, you can find that you can now activate doze on the go.
    10-06-2016 05:46 PM
  7. Gray Area's Avatar
    I clicked the driver from the link you posted but It doesn't do anything, is there another place to get adb?
    10-06-2016 05:49 PM
  8. chanchan05's Avatar
    The driver isn't ADB. That's different. ADB's official source is from the Android Dev's site and its part of the 25GB download for Android studio.
    10-06-2016 07:08 PM
  9. Gray Area's Avatar
    OK thanks, I'll check it out
    10-06-2016 07:48 PM
  10. Est_XCIV's Avatar
    You can enter the second and last command and it should work. I do it have a rooted phone and it is not necessary to do so for this. Also AOD works perfectly.
    10-07-2016 09:54 AM
  11. victoryrules8's Avatar
    Any tips for using greenify on a non rooted device? Or does it pretty much just do its thing ?
    10-07-2016 03:17 PM
  12. chanchan05's Avatar
    Depends on what you want it to achieve. I don't use it to hibernate apps. Just for the aggressive Doze and Doze on the go.
    10-07-2016 05:55 PM
  13. victoryrules8's Avatar
    Well.i want it to help in conserving battery life. Does it just work or do I have to fine tune it?I see the aggressive size feature how does it work?
    10-07-2016 06:22 PM
  14. chanchan05's Avatar
    Just turn it on. It will go into Doze faster than normal, hence increasing standby time. You'd also want to enable Doze on the Go.
    10-07-2016 06:51 PM
  1. Battery Drain When A5 2016 is Off
    By k1fox in forum Samsung Galaxy A5
    Last Post: 04-02-2017, 05:10 AM
  2. 6.0.1 update murdering battery
    Last Post: 10-06-2016, 04:40 PM
  3. my samsung note 3 mobile cannot log in gmail
    Last Post: 10-06-2016, 04:09 PM
  4. Replies: 0
    Last Post: 10-06-2016, 07:33 AM
  5. Replies: 0
    Last Post: 10-06-2016, 06:32 AM
