1. MaryS910's Avatar
    I posted about this after I got my Samsung in June but it's still not working right. Most of my family and friends have iPhones and when a group text is initiated, especially if there is a photo or video, I only see a few comments. I'm using the stock texting app but tried a few others back in June with no success. Have any of you in a similar situation managed to resolve this? Thanks!
    10-08-2016 02:12 PM
  2. parthtc09's Avatar
    Hey! I was in the same situation as you. Did you have an iPhone prior to getting the galaxy? If so you need to disable imessage , if you don't have your iPhone anymore go here https://selfsolve.apple.com/deregister-imessage and enter your number. Apple will de-register it. Also have your family members check your contact on their phones as your number may be saved under "iPhone". I had to do both before I could start getting group messages.
    T48 likes this.
    10-08-2016 05:02 PM
  3. Andrew Read1's Avatar
    Surely their group messages will be sent as imessage in which case you won't be involved.
    10-09-2016 12:46 AM
  4. MaryS910's Avatar
    I unregistered my number back in June using that link. Are you saying that on their contact lists they need to change me from iPhone to mobile or home? I thought those were just descriptions to clarify a person's different numbers. Are you saying if they have me still listed as "iphone", it changes how their messages to me are sent?
    10-09-2016 12:12 PM
  5. parthtc09's Avatar
    Yeah, that's how it was for me, they all had me saved as iphone, I saved mine as mobile and voila all messages came through.
    10-09-2016 12:24 PM
  6. MaryS910's Avatar
    Parthc09, you mean that your friends changed you from iPhone to mobile in your profile on each of their phones, right?
    10-09-2016 03:51 PM
  7. parthtc09's Avatar
    Yes, after they changed my number from iPhone to mobile, I was able to receive group texts
    10-09-2016 05:00 PM
  1. Replies: 2
    Last Post: 08-28-2017, 03:22 AM
  2. Why would a message say hidden sender address & not diwnload
    Last Post: 11-06-2016, 02:05 PM
  3. Does the Moto Z Play have any Gorilla Glass in the screen?
    Last Post: 10-14-2016, 05:04 AM
  4. How do I delete QuickOffice from my Android Max apps?
    Last Post: 10-14-2016, 05:03 AM
  5. How do i deny a "text read" report to someone else?
    By brpost in forum Android 6.0 Marshmallow
    Last Post: 10-08-2016, 03:10 PM
