1. randun's Avatar
    Got my new Edge & love it.
    Got a quirky thing happening though. For some reason, Twitter will not save my notification sound!
    Had this happen with another app but there was an internal fix for it. Given that Twitter has zero Support, was wondering if anyone else here had experienced this.
    10-11-2016 04:07 PM
  2. Deanig_12's Avatar
    twitter as just this min had an update don't know what for tho
    randun likes this.
    10-11-2016 04:17 PM
  3. randun's Avatar
    I'll check it out though it seems they have updates about twice a week. 😃
    10-11-2016 04:49 PM
  4. randun's Avatar
    There was no update for my phone
    10-11-2016 04:54 PM
  5. KPMcClave's Avatar
    It's been an ongoing issue for quite a while. I'm still living with it since getting my S7E back in mid-March. I believe it's an issue on the Twitter side of things. There's no "OK" or "Save" option when you select a new tone. Backing out in other apps will save the selection anyway, but not in Twitter (obviously).
    randun likes this.
    10-11-2016 11:13 PM
  6. randun's Avatar
    Was pretty sure it was on the Twitter end. Unfortunately, their support is useless.
    10-16-2016 05:34 PM
  1. Unable to disable app notification on 6.0.1
    Last Post: 10-18-2016, 04:56 AM
  2. Camera gets blurry, makes rattling sound and won't focus
    Last Post: 10-11-2016, 03:50 PM
  3. Replies: 1
    Last Post: 10-11-2016, 03:41 PM
  4. Replies: 6
    Last Post: 10-11-2016, 11:33 AM
  5. Double Notification voicemails
    By patcal in forum Samsung Galaxy S7 edge
    Last Post: 10-11-2016, 11:16 AM
