1. mushie143's Avatar
    Like others on the forum my battery is draining very quickly. I searched my application manager and it does not show Oculus. The only thing I have is Gear VR. The only options it has is disable and force stop; which I did but it still shows it is quickly draining my battery. Any thoughts on where Oculus is? Or how to stop Gear from draining my battery?
    10-11-2016 04:51 PM
  2. nahoku's Avatar
    If you're not using anything that requires Gear VR, install Package Disabler Pro and disable Gear apps.
    10-11-2016 05:38 PM
  3. T48's Avatar
    I was looking for that too when messing with one in a store. Was kind of curious where Oculus was located as well?
    10-11-2016 06:16 PM
  4. angiebugg's Avatar
    Me too
    10-13-2016 10:28 PM
  5. mundo472's Avatar
    I've had huge improvement in the battery drain issue after loading the update for "Android System WebView" yesterday.
    10-14-2016 08:20 AM
  6. mushie143's Avatar
    Thanks for the info - I d/l & disabled this but battery is still horrible.
    10-14-2016 11:23 AM
  7. mushie143's Avatar
    Is there anyway to get the update beside through the playstore? The latest version it has for me is 53.xxx
    10-14-2016 11:25 AM
  1. Wow! No Google warranty unless phone is purchased in Google Store!!
    By jimbo1mcm in forum Google Pixel & Pixel XL
    Last Post: 10-15-2016, 12:24 PM
  2. Work in construction, need case suggestions
    By Scousejay1972 in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 10-13-2016, 07:31 AM
  3. Why does my boyfriend receive messages in Japanese?
    Last Post: 10-12-2016, 03:52 PM
  4. Replies: 1
    Last Post: 10-11-2016, 03:47 PM
  5. Replies: 1
    Last Post: 10-11-2016, 02:19 PM
