1. C0NFUS3D's Avatar
    Some of my songs have (1) and (2) at the end of each. Why?
    10-12-2016 05:45 PM
  2. B. Diddy's Avatar
    How did you transfer the song files? Can you locate the files in their directory using My Files or some other file manager app? Chances are that you have duplicates of those music files.
    10-12-2016 08:10 PM
  3. C0NFUS3D's Avatar
    I transfered the songs using the wires they give you. I can locate the files using My Files.
    10-13-2016 06:31 AM
  4. B. Diddy's Avatar
    And do you see duplicates of any of the files? A duplicate file will usually cause a number to be added in the file name.
    10-13-2016 04:37 PM
  5. C0NFUS3D's Avatar
    I see that it's a duplicate. My question is why is it there?
    10-13-2016 06:57 PM
  6. B. Diddy's Avatar
    I'm not familiar with the method you used to transfer your data, but the file was presumably copied twice, either by accident or through a bug in the system.
    10-13-2016 09:50 PM
  1. galaxy s4 says my email server password has changed
    Last Post: 10-13-2016, 03:19 AM
  2. Replies: 1
    Last Post: 10-12-2016, 10:36 PM
  3. Replies: 2
    Last Post: 10-12-2016, 10:17 PM
  4. why my note 7 comes with a screen protector? bestbuy
    By Shaodong Lin in forum Samsung Galaxy Note 7
    Last Post: 10-12-2016, 08:59 PM
