1. Sam1482's Avatar
    Can anyone tell me if the otterbox defender on the s7 edge will work with Samsung wireless charging stand thanks
    10-13-2016 04:17 AM
  2. jsk0703's Avatar
    Hmm, I can't say for sure but I have the Otterbox symmetry case and it works just fine.
    10-13-2016 04:45 AM
  3. naturalguy's Avatar
    Yes it works
    10-13-2016 07:24 AM
  4. Sam1482's Avatar
    Cheers
    10-13-2016 10:21 AM
  5. Rob.G's Avatar
    I have a Pelican case (don't recall the model) and the wireless charging doesn't work well for me. I'm going to return the charging pad as a result.
    Edit: My mistake; I reread the web page, and it does include one. Sure didn't look like it to me.
    10-14-2016 10:40 AM
  6. Airmaxxx's Avatar
    Yes it does
    10-15-2016 01:38 PM
  7. justin1578's Avatar
    It didn't on mine. Using the Defender or Symmetry works for a few minutes, slowly, then the light starts blinking and the charge stays at whatever # it is. I looked up what that means when the light is blinking, it said you are using an unsupported device. I just take my Symmetry off when charging.
    10-15-2016 04:57 PM
  8. mmcclure0453's Avatar
    I had the Samsung fast wireless charger for my S7E and it made the phone very hot no matter what case I had on it. Ended up selling it.
    I now have the Tylt charger stand and it works great with my Defender case, Symmetry case, Commuter case, and my SupCase. Doesn't heat the phone and does not charge at a snails pace. Only thing is that I have to use a spacer about the diameter of a pencil to raise the phone just a touch. Won't charge if it's sitting all the way down in the charger.
    I'd rather lift the phone a little than have the phone burning up on the charger...
    10-15-2016 06:02 PM
  1. S7 battery problem?
    By Chalanthorn Chanmathikornkul in forum Samsung Galaxy S7
    Last Post: 10-20-2016, 09:31 PM
  2. Galaxy S7 Edge front facing camera negative photo.
    By traneupcqk in forum Samsung Galaxy S7 edge
    Last Post: 10-15-2016, 12:25 AM
  3. Edge 7 with Note 7 features
    By Longhorngary in forum Samsung Galaxy Note 7
    Last Post: 10-14-2016, 05:46 AM
  4. What's that yellow dot light above the samsung logo of this s7 edge ?
    By Matt Gomont in forum Samsung Galaxy S7 edge
    Last Post: 10-13-2016, 11:41 AM
  5. New phone s7 edge
    Last Post: 10-13-2016, 01:50 AM
