which unlocked 7edge Variant is the best one for the US?
victoryrules8
358
It seems like there's lots of variants of this phone. my only issue with buying the actual unlocked one that they made just for the US is that it has only received 1 update since it's launch in June. Are the other variants any better? Which is the best one?
tgp
Trusted Member
Nov 15, 2011
761
First of all, are you on Verizon or Sprint, or any MVNO using their service? The US unlocked version is your only option if you are.
If you are using AT&T or T-Mobile service, then you can also use an international version. You should research LTE bands; your carrier's LTE may not be covered.
djepperson1
281
I have the USA version 4 days ago I received a second update with September security patches I love this phone. It's the 935u version
adelinachau53674
