1. victoryrules8's Avatar
    It seems like there's lots of variants of this phone. my only issue with buying the actual unlocked one that they made just for the US is that it has only received 1 update since it's launch in June. Are the other variants any better? Which is the best one?
    10-13-2016 07:26 AM
  2. tgp's Avatar
    First of all, are you on Verizon or Sprint, or any MVNO using their service? The US unlocked version is your only option if you are.
    If you are using AT&T or T-Mobile service, then you can also use an international version. You should research LTE bands; your carrier's LTE may not be covered.
    10-13-2016 08:09 AM
  3. djepperson1's Avatar
    I have the USA version 4 days ago I received a second update with September security patches I love this phone. It's the 935u version
    10-13-2016 08:57 AM
  1. Is my phone dead??
    By Zadenaki Kante in forum Samsung Galaxy S4
    Last Post: 10-22-2016, 07:57 PM
  2. What is Media Server
    By scottwalton in forum Samsung Galaxy S7
    Last Post: 10-13-2016, 01:47 PM
  3. Replies: 1
    Last Post: 10-13-2016, 07:21 AM
  4. Replies: 0
    Last Post: 10-13-2016, 06:30 AM
