1. Eric Lipkind's Avatar
    I just switched from the Note 7 to the S7 edge. On the Note 7, there was some setting which allowed to phone to automatically switch to wifi and connect when I was home. Where is this setting on the Edge?
    10-13-2016 09:33 PM
  2. parthtc09's Avatar
    Hey! There is something called my locations, only works if you keep GPS on. Swipe to open the edge bar and click the cog to open the edge screen settings. Look for an edge with the text "manage function and apps useful in specific places". Set that as an active edge app, open it and configure what you need.
    10-13-2016 09:40 PM
  3. Eric Lipkind's Avatar
    Thank you!
    10-13-2016 09:45 PM
  1. T-Mobile to Project Fi: which WiFi router do I go with?
    By quelquehomme in forum Google Project Fi
    Last Post: 12-27-2016, 11:42 AM
  2. Android Auto Searching for GPS
    By AC Question in forum HTC One M8
    Last Post: 10-13-2016, 07:51 PM
  3. WiFi calling on T-Mobile
    By srgonu in forum OnePlus 3 & 3T
    Last Post: 10-13-2016, 04:03 PM
  4. Replies: 1
    Last Post: 10-13-2016, 03:28 PM
  5. I want to change an auto answer.
    Last Post: 10-13-2016, 01:10 PM
