1. Eric Lipkind's Avatar
    On the Note 7, the small weather widget on the home screen could be stretched/resized. On the Edge, I can't figure out how to do it. Any ideas?
    10-13-2016 09:34 PM
  2. neo999's Avatar
    If you are talking about the stock widget, I couldn't get that one to stretch all the way across the screen. On either phone. Take a look in the widgets. There is another version that spans 5 x 1. I think it should work if you using 5 x 5 grid or smaller.
    10-14-2016 08:25 AM
  3. Eric Lipkind's Avatar
    Interesting. The larger one you can shrink by 1 box on the 5x5. However it puts the time on the top right and weather on bottom left with gaps in the other corners. I wasn't definitely able to resize the small widget on the Note 7. I did notice that the small widget on the Note 7 included high/low. On the Edge it does not. The weather portion of the large widget on the Edge is what my small widget looked like on the Note 7 (i.e. the time portion was not there).
    10-14-2016 08:37 AM
  4. Eric Lipkind's Avatar
    Correction. I was able to fix the corner issue by shrinking to 5x1 from 5x2.
    10-14-2016 08:39 AM
  1. Pixel Google Widget Question
    By mhinc in forum Google Pixel & Pixel XL
    Last Post: 10-14-2016, 08:22 AM
  2. Where are the widgets?
    Last Post: 10-14-2016, 04:32 AM
  3. default weather widget connection failure
    By Seongjinkim73 in forum Ask a Question
    Last Post: 10-13-2016, 03:10 AM
  4. Unlocked Moto Z Moto Widget
    By accordex#AC in forum Moto Z & Moto Z Droid Edition
    Last Post: 10-12-2016, 08:14 AM
  5. Adding widgets to Edge Tasks Panel?
    By Pinmac in forum Samsung Galaxy S7 edge
    Last Post: 10-12-2016, 07:30 AM
