1. jjdelarosa10's Avatar
    I have a s7 edge and two days ago I started having issues with my phones speaker. I noticed that if I made a call and put it on speaker I was unable to hear the other person. If I took them off speaker it would work fine. Then YouTube, fb, Instagram, Spotify, and twitter videos are now the same. They won't play through my speaker. It will only play for like 5 sec with sound then go away. If I put headphones the issue is totally gone and also if I put an aux cord. How can I fix this I'm thinking it could be a bug. I need help please this is annoying.
    10-13-2016 11:05 PM
  2. B. Diddy's Avatar
    Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-28008
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    10-15-2016 02:47 AM
  1. I am unable to delete or download files to sd card .
    Last Post: 04-12-2017, 02:56 PM
  2. Replies: 3
    Last Post: 10-14-2016, 12:17 AM
  3. s7 Edge LED case
    By Eric Lipkind in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 10-13-2016, 09:36 PM
  4. s7 edge screen replacement
    Last Post: 10-13-2016, 08:48 PM
  5. Can my synced tablet help me unlock my galaxy s7?
    Last Post: 10-13-2016, 08:21 PM
