1. Sam1482's Avatar
    Is any one getting better battery or the same as note 7 cause my s7 edge isn't as good as my note 7 and it's set up the same
    10-14-2016 05:08 AM
  2. SpookDroid's Avatar
    I didn't notice any big difference on the S7 Edge when I had it, but then again, the Note 7 does have a much larger battery, so expecting the same life wouldn't be fair. Unless you're getting an hours-long difference, then yeah, something might be off.
    10-14-2016 05:12 AM
  3. chanchan05's Avatar
    The S7 Edge has a bigger battery.
    S7 - 3000mah
    Note 7 - 3500mah
    S7 Edge - 3600mah
    jbcatl likes this.
    10-14-2016 05:20 AM
  4. Sam1482's Avatar
    The phone has been off charge for 5hr 10 mins with 2hrs screen on time and it's at 65% note 7 would be at 70-75
    10-14-2016 06:00 AM
  5. SpookDroid's Avatar
    S7 - 3000mah
    Note 7 - 3500mah
    S7 Edge - 3600mah
    My bad, I was thinking of the S7. I blame it on jet lag. Mea culpa. Thanks for the clarification, though!
    10-14-2016 06:43 AM
  6. lizette1222's Avatar
    I went to sleep and my battery was at 60, and I woke up at 37. So I do notice that my battery is not that good as the note 7...I used to get 5 hours screen on time with the note.
    10-14-2016 06:58 AM
  7. Sam1482's Avatar
    I'm in the UK I was getting 6hr screen on time with me note it has only been charged twice though so maybe a few more charges and it will be as good as the notes
    10-14-2016 07:02 AM
  8. ZOMMBIE1's Avatar
    I was getting better battery life on my S7 edge over the N7. Im back on another S7 edge and its still gets better Battery life.
    10-14-2016 07:05 AM
  9. chazglenn3's Avatar
    This will be my first day with my S7 edge so I'll hold off on any battery comparisons for a few days. My original Note 7 battery wasn't as good as my replacement Note 7 battery was, that's for sure.
    10-14-2016 07:36 AM
  10. jbcatl's Avatar
    My S7 Edge battery life is much better than even my replacement Note 7, which was pretty good. The Edge seems to sip battery. I installed a ton of apps yesterday after going off charger around 6:30AM, and still have over 50% at 10PM. I haven't started playing games or anything yet.
    10-14-2016 08:56 AM
  11. phone-a-holic's Avatar
    Well I now have the s7 edge. Boy do I miss my note 7 but I seem to be getting better battery life from the edge
    10-14-2016 11:58 AM
  12. 68bowtie's Avatar
    I got much better battery from my 2nd note 7 then from both my replacement s7 edge phs.
    10-14-2016 12:07 PM
  1. Replies: 1
    Last Post: 10-14-2016, 10:07 AM
  2. Trade in Note 7?
    By EmanC19 in forum Samsung Galaxy Note 7
    Last Post: 10-14-2016, 08:33 AM
  3. Replies: 4
    Last Post: 10-14-2016, 06:09 AM
  4. Replies: 2
    Last Post: 10-14-2016, 05:55 AM
  5. Replies: 2
    Last Post: 10-14-2016, 05:02 AM
