1. ekirsh's Avatar
    I finally gave in and traded in my Note 7 for an S7 Edge. Before taking the phone in, I made sure that I had a complete backup to my Samsung account. When I got my new phone, I used Smart Switch, with a cable, to move over the small stuff, and I figured I'd simply resync my music with my PC, but it told me that it would take over an hour to copy over apps and settings, so I figured I wouldn't bother doing that in the store. After all, I had a full backup.
    But on the S7 Edge, when I go to "Backup and Reset", there's no section for "Samsung Account" (just "Google account"). Googling implies that there should be. I'm logged in to my Samsung account, and it isn't disabled.
    What am I missing? I had a *lot* of apps on my old phone, and a fairly complicated home screen setup, and I'd really rather not have to spend the time recreating it. Also, I'd like to be able to back up in the future.
    dlgus likes this.
    10-14-2016 11:56 PM
  2. chanchan05's Avatar
    Well, you need to wait for the updates. The S7 only received Samsung backup shortly after the Note 7 was released via software update. So you should check if you have software updates available.
    10-15-2016 01:55 AM
  3. ekirsh's Avatar
    Thanks. An update was, in fact, pushed overnight, but I still don't see it. Is there something I need to do to enable it?
    10-15-2016 10:42 AM
  4. _Dark_fulgore_'s Avatar
    Im having the same issue... so frustrated lol
    10-16-2016 10:37 PM
  5. chanchan05's Avatar
    You need to get to the September update. You'll be receiving the updates one by one every few hours.
    10-16-2016 10:48 PM
  1. Replies: 52
    Last Post: 10-18-2016, 01:16 PM
  2. Note 7 to asus zenfone 3 deluxe
    By hou33guy in forum Samsung Galaxy Note 7
    Last Post: 10-17-2016, 05:14 PM
  3. What to do... On Vacation in Mexico with ATT Note 7!
    By Wbrian in forum Samsung Galaxy Note 7
    Last Post: 10-16-2016, 11:43 PM
  4. Live stream to see how long it takes to blow up!
    By sh0tta in forum Samsung Galaxy Note 7
    Last Post: 10-15-2016, 11:08 AM
  5. Will they send me a box to send my phone back in?
    Last Post: 10-15-2016, 05:26 AM
