1. Momof9Blessings's Avatar
    Well I finally had time to play with my pen... I bought an Intuos Creative Stylus 2 from Best Buy. It is designed for the iPad but works great using the bluetooth on my s7E. I also downloaded Google's Handwriting Input App and it works great! It is an alternative keyboard.
    I need to see if the pen has pressure sensitivity. But I like it much better than using a rubber tip pen...
    10-16-2016 02:50 PM
  2. rsmin's Avatar
    Should be able to download snote to the s7e as well.
    10-16-2016 03:10 PM
  3. skatergirl's Avatar
    I am glad you posted this. When you first posted I looked at the pen and it said it was for iPads. I am now going to look for one. Just sad there is no where in the phone to store it.
    10-16-2016 03:39 PM
  4. WingLT's Avatar
    By any chance could you test this out on some of the art programs like Artflow, Artrage, Sketchbook?
    10-16-2016 04:49 PM
  5. Rukbat's Avatar
    That's the big failure, skatergirl - there are a lot of good styli, but you still need a pocket or something to store it.
    10-16-2016 04:49 PM
  6. WingLT's Avatar
    I don't care if there is a slot or not for the pen. I usually use the old Note 2 pen accessory. Which is big like a normal size pen
    10-16-2016 05:01 PM
  7. hasasimo's Avatar
    I kept the S-Pen from my Note 7 when I returned the phone. Wonder if I can get it to stick to the top (metal portion) of the S7E with a magnetic strip.
    10-16-2016 09:51 PM
  8. lizardchest's Avatar
    The S-Pen from the Note 7 does not work with the S7/S7E.
    hasasimo likes this.
    10-17-2016 08:27 AM
  9. Momof9Blessings's Avatar
    I have used the pen in art rage etc. It works fine, but no pressure sensitivities as far as I can tell. I am curious about the jot pro and stilo. They might work as well
    10-24-2016 06:48 AM
  1. Those who are frustrated with Samsung should let Samsung know about it
    By Roman Akert in forum Samsung Galaxy Note 7
    Last Post: 10-18-2016, 09:58 AM
  2. Always on display on Galaxy S7
    By sammy808 in forum Samsung Galaxy S7
    Last Post: 10-17-2016, 02:12 PM
  3. Can I replace my S6 camera with an S7 camera unit?
    Last Post: 10-16-2016, 05:31 PM
  4. How do I change mirror image for selfish on galaxy s7?
    Last Post: 10-16-2016, 04:41 PM
  5. HTC ONE M8 is showing red triangle with exclamation sign
    Last Post: 10-16-2016, 02:06 PM
