1. bialy's Avatar
    How big an issue is the ergonomic one of accidentally activating the lower corner of the screen with ones palm due to the gentle curved edge? Problem or not?
    10-17-2016 07:13 PM
  2. blackhemi4x4's Avatar
    I've never done it. Looking at it now and my palm actually never touches it.
    10-17-2016 07:18 PM
  3. chanchan05's Avatar
    Haven't experienced an issue, but I slapped a case on it as soon as I got the phone, even before turning it on for the first time after inserting a SIM, and the case helped a lot in ergonomics.
    10-17-2016 07:23 PM
  4. amyf27's Avatar
    I haven't done that. I have an Otterbox Symmetry case on mine and it gives a nice edge frame
    10-17-2016 08:22 PM
  5. nndlb123's Avatar
    I do it all the time but adding a case resolves the problem.
    jbjtkbw007 likes this.
    10-18-2016 05:06 AM
  6. Nakrohtap's Avatar
    Agree with all of these...with a case, it's not an issue. I just got mine yesterday and the edges don't seem that much different from the Note7's. I thought it would be more drastic.
    10-18-2016 05:16 AM
  7. mvsmith's Avatar
    Yep for some reason it's not a problem with a case. Using a case mate and no problem. Was in gear VR and forgot to put case back on and couldn't type in passwords or logins because my hand was holding the edge side. Really annoying. I got a cheap insignia case for my loaner s7 edge back during the n7 recall and it was bad with that case.
    I'm sure most of the cases out there Spigen, OtterBox, casemate and everything will be fine. The one I had was basically just a bumper.
    10-18-2016 01:47 PM
  8. bialy's Avatar
    Wouldn't a case defeat the whole benefit of the Edge screen (if one wanted that benefit) ?
    10-18-2016 03:14 PM
  9. Nakrohtap's Avatar
    Nope. The edge is still there. You're just not touching it while holding the phone because the case extends it outwards a few mm.
    Instead of your fingers wrapping around the screen, it's around the bumper.
    10-18-2016 03:26 PM
  10. merlinskw's Avatar
    A nice case makes the edge quite nice, I didn't like it bare, now I really enjoy the phone.
    10-18-2016 03:46 PM
  11. amyf27's Avatar
    Yes the edge is still definitely usable I just haven't set mine up yet I've only had the phone in about 24 hours
    10-18-2016 04:14 PM
  1. Unlocked or Verizon Z play?
    By Mexico619 in forum Moto Z Play & Z Play Droid Edition
    Last Post: 10-18-2016, 06:17 PM
  2. Replies: 1
    Last Post: 10-18-2016, 04:03 AM
  3. Replies: 1
    Last Post: 10-18-2016, 03:59 AM
  4. Replies: 1
    Last Post: 10-18-2016, 01:20 AM
  5. Replies: 0
    Last Post: 10-17-2016, 06:30 PM
