1. bialy's Avatar
    Besides the obvious of speed, what are pro's & con's of Fast vs Regular charging ?
    10-17-2016 08:18 PM
  2. Aquila's Avatar
    Fast charging can generate heat, which is not good for batteries and can lessen their capacity over time. On a normal 1-2 year upgrade cycle the impact appears to be minimal, however for folks keeping their devices for 3-4 years that could pose a problem. At the same time, it may be at a higher heat but for far less time so the total damage could be negligible when compared to charging slower for longer.
    10-17-2016 08:23 PM
  3. aldo82's Avatar
    My phone doesn't always charge fully on slow charging over night. It's like the slow charging is sometime really really slow! Not sure why. Fast charging is therefore more reliable as I know I'll get a full battery but I do try to stick with slow when I can as I expect it's better for battery health in the long run
    10-18-2016 01:04 AM
  4. Roman Akert's Avatar
    Slow charging seems to result in better battery life. It's also better for the battery.
    Use fast charging when time is of essence, otherwise switch it off.
    10-18-2016 05:47 AM
  1. Battery won't charge past certain percentage
    Last Post: 02-22-2017, 09:55 AM
  2. LG V20 vs S7e vs S8 replace
    By bialy in forum Samsung Galaxy Note 7
    Last Post: 10-21-2016, 11:55 PM
  3. My note 5 will not fast charge
    Last Post: 10-18-2016, 03:01 PM
  4. Replies: 2
    Last Post: 10-17-2016, 05:24 PM
  5. is it worth buying Samsung Note Pro 12.2 in late 2016?
    Last Post: 10-17-2016, 10:30 AM
