1. recDNA's Avatar
    I'm a note 7 refuge. Considering many options. One is s7e. Thing is all Sammy phones I've owned have been slow despite applying all the suggested "cures". Is the s7e a fast phone? Is it as fast as the 6p for example? Is it as fast as the latest Moto offering (force or whatever it's called)? I appreciate your input and examples. Thanks
    10-18-2016 12:16 PM
  2. amyf27's Avatar
    I have no complaints so far, but then again I've only had the phone about 20 hours. I use Nova Launcher which has been great
    10-18-2016 12:25 PM
  3. recDNA's Avatar
    I use Nova Launcher too so that is a good comparison. When you scroll through twitter or tapatalk or anything involving scrolling is it smooth? It was jumpy in my N3 and N7.
    10-18-2016 12:54 PM
  4. amyf27's Avatar
    For me it's been smooth
    10-18-2016 12:59 PM
  5. amyf27's Avatar
    You can customize the scroll speed too, I just haven't done that
    10-18-2016 12:59 PM
  6. merlinskw's Avatar
    I also came over from the Note7. I went with the S7edge. It's not the Note7, but with a good launcher like nova, action 3, etc it's nice. Also a good case helped thin down the edges. Hope this helps. Good Luck
    10-18-2016 01:36 PM
  7. recDNA's Avatar
    My Note 7 wasn't very good so when people say this is almost as good I know it is meant as a compliment but not so much to me.
    My scroll speed isn't/wasn't the issue. It was scroll smoothness.
    10-18-2016 01:49 PM
  8. nettech207's Avatar
    I came from a iphone 6plus and note 4 previous to that touchwiz has defiantly improved as a aluncher since the note 4 and the smoothness of marshmellow is on par with ios haven't seen that much lag on my s7edge
    10-18-2016 02:19 PM
  9. anon(8413510)'s Avatar
    Had my S7 Edge for 4 days and I fm gotta say this thing is fast ( Exynos SOC) for the 1st time in years I haven't replaced Touchwiz with Nova prime.
    Touchwiz is really smooth and snappy and I really couldn't be happier, great battery life as well.
    Absolutely zero lag experienced :-)
    10-18-2016 03:47 PM
  10. glenninduluth's Avatar
    Note 7 and now S7 Edge are the first two Samsung phones I've had where I didn't feel a need to use a third party launcher. Personally never felt that the Note 7 lagged at all, but the S7 Edge does seem to feel a bit faster than the Note 7 to me.
    10-18-2016 03:59 PM
  11. chanchan05's Avatar
    Don't believe any ad you say that claims they'll speed up the phone. In all cases they slow it down more.
    amyf27 likes this.
    10-18-2016 05:04 PM
  12. tadpoles's Avatar
    Out of habit I disable everything I consider bloats (Instagram, Facebook, AT&T Locker, AT&T Drive Mode, Google Drive, Device Help, Hangouts, and a slew of others). I also use Nova Prime. With this method I've been able to make a lot of phones perform pretty well, even my Mum's LG Phoenix 2 with its 1.5GB of RAM. My S7e just flies and I really love the performance. No stuttering, no lag. YMMV
    10-19-2016 02:32 PM
  13. mediaseth's Avatar
    My edge is painfully laggy. I think I have defective model or something got screwed up with the OS/apps. I can't even get pages manager to work, which I need for my business. Pressing the home button has no result.. press again.. delay.. finally goes back to home screen. My s6 wasn't a problem. My note7's weren't a problem. My edge7 is a big headache.
    10-19-2016 02:47 PM
  14. jackattack 82's Avatar
    Smooth as silk here on my S7 Edge, coming from Note7 (Note 4 prior). I have gotten used to it much faster than I thought, couple complaint I have are no secure folder and AOD lacks proper notifications for all 3rd party apps. (pointless when you cant see notifications)
    10-19-2016 04:12 PM
  15. Nakrohtap's Avatar
    My first Note7 keyboard/screen presses were a little hit and miss. My replacement Note7 was better. My new S7E seems to respond much better. No missed presses. Keyboard seems silky smooth now. I definitely think there was an issue with the Note7 sensitivity using their new screen technology.
    http://<br /> http://www.phonebunch....923.html<br />
    10-19-2016 04:29 PM
  1. is it worth buying Samsung Note Pro 12.2 in 2016 or early 2017?
    By kuraizo in forum Samsung Galaxy Note Pro 12.2
    Last Post: 02-14-2018, 02:03 AM
  2. Unable to make or receive calls
    By semajm in forum Huawei P9 & P9 Plus
    Last Post: 10-20-2016, 10:14 PM
  3. Replies: 4
    Last Post: 10-18-2016, 09:46 AM
  4. Replies: 0
    Last Post: 10-18-2016, 07:12 AM
  5. Why does the 'wake screen' padlock disappear so fast?
    Last Post: 10-18-2016, 05:22 AM
