02-21-2017 08:12 AM
274 ... 891011
tools
  1. KupKrazy's Avatar
    another first today, i was asked for the 3 digit security code on the back. I see the (generated) last 4 digits but wasnt sure if i should have just used the 3 digit code on back of card or where to look. It was at a Loves truckstop and they always ask for the 3 number code on the back when i use my regular card too.
    Interesting, I have never been asked for the CVC code unless it was for a purchase where the card was not physically present (like online shopping). That's weird.
    01-05-2017 11:40 PM
  2. amyf27's Avatar
    I don't think it's possible to shut off samsung pay. Walmart has Walmart pay and it works there. Samsung works on any kind of card reader I've tried, "tap and pay" or not, it works
    01-06-2017 04:09 AM
  3. amyf27's Avatar
    I used it at a Family Dollar store today. I received a card error three times so I moved it to the top of the reader to use NFC & received the card error again. I knew it had to work because I have used it in that same store and other Family Dollar stores. On the 5th try I moved my phone up a little more on the card swipe & it went through. LOL...I'm learning to not give up. Majority of the time if I get an error it is usually the cashier or my fault.
    Lol. Matter of placement and cashier screen set
    01-06-2017 04:10 AM
  4. amyf27's Avatar
    You'll see the four digit code on the front of the Samsung pay version of your cards it'll say give this number to cashier.
    01-06-2017 04:11 AM
  5. amyf27's Avatar
    This morning at Bob Evans. Worked like a charm.
    Serkle K likes this.
    01-06-2017 07:00 AM
  6. mikeshauling's Avatar
    I gave that code, didnt work. Its just a LOVES truck stop thing. THey always ask for the 3 ccv code when using cc. This was the 1st time i tries samsung pay there. I will try using the actual card 3 digit ccv next time i guess
    01-06-2017 04:57 PM
  7. KupKrazy's Avatar
    Actually, the CVC code isn't the 4 digit code listed on Samsung Pay.. that's just the last 4 digits of the faux CC number that it created for your card that sometimes the cashier needs to complete the transaction.
    The CVC security code is usually the 3 digit number that is listed on the back of the credit card, or the 4 digit number printed on the front of an Amex card. I am only usually asked for this when using my card when ordering something online or where I am not using my card physically.
    01-06-2017 11:56 PM
  8. amyf27's Avatar
    Went to a small Italian pizza shop. They pulled out their little portable card reader and he was bewildered when I paid with my phone.
    01-10-2017 11:41 AM
  9. Doug Fitton's Avatar
    I love when that happens it just amazes people
    amyf27 and Serkle K like this.
    01-15-2017 06:10 PM
  10. pinkivy98's Avatar
    I just encountered this for the first time. I was at Kroger Turkey Hill Gas station. It was a convenience store separate from a Kroger. The card reader was attached to the screen & the cashier took my phone to scan, it went through but asked for the 3 digit code so I had to use a different payment method. There were at least 3 other stores nearby so I never would have stopped here if I had known Spay would not work.
    01-19-2017 09:40 PM
  11. mikeshauling's Avatar
    did you try the 3 digit code thats physically on your card ? I am next time , just to see if it works.
    01-19-2017 10:09 PM
  12. WingLT's Avatar
    next time make sure when the screen pops up for your pin, don't put your pin in, make sure you run it as credit. I think I figured that if you try to put your pin in it doesn't work, because that pin is for your card, not the card the Samsung pay is attached to.
    It used to work two months ago. But ever since the recent updates the payment will only go through as credit now. This can be annoying if I need to take out money from my account using debit. Can't do that now.
    01-20-2017 12:53 AM
  13. WingLT's Avatar
    I had an interesting one today. I was paying for postage at the post office with my phone and I scanned it on their scanner. Their scanner said put in the last four digits and according to Samsung pay it was not the four digits of the card it was an encoded four digits those four digits did not work the ones that did work were the actual last 4 digits on the credit card that's in Samsung pay. I'm not sure why that would be but at least it worked.
    Ok you got me confused... Which four digit pin worked? The ones on your actual card? Or the ones from Samsung Pay?
    01-20-2017 01:07 AM
  14. amyf27's Avatar
    The one that worked is not the one that samsung pay tells you to give the cashier
    01-20-2017 04:01 AM
  15. amyf27's Avatar
    I had a little entertainment again yesterday. I paid at Applebee's to go . I reached over and held it over the card slide built into their register and they were just looking at me like I had magic powers.😄
    sweetypie31 and jamezr like this.
    01-20-2017 04:03 AM
  16. jamezr's Avatar
    Lol....nice cheap entertainment huh! I love it when the cashier tells me "its not set up for mobile payment"......then watches as i use my S7 edge to pay......
    pontiac005 likes this.
    01-20-2017 06:37 AM
  17. pinkivy98's Avatar
    No, I did not but I just remembered I keep that info in a password app on my phone so I will look it up the next time.
    amyf27 likes this.
    01-20-2017 10:55 AM
  18. WingLT's Avatar
    The one that worked is not the one that samsung pay tells you to give the cashierhttps://uploads.tapatalk-cdn.com/201...35968f966b.jpg
    And the four digit pin for your card doesn't work either. Tried it several times. It used to work but with the recent updates it stopped working. So which four digits worked?
    01-20-2017 01:03 PM
  19. amyf27's Avatar
    The one circled in red worked for me
    01-20-2017 01:10 PM
  20. WingLT's Avatar
    It didn't work... I've tried everything now. The pin for the card, the last 4 numbers for the card number, and the Pin that Samsung wants me to use. Nothing works. Getting pissed off now because payment shouldn't go through only as credit. It's insane now... And sometimes I need to get money out of my account and I can't do it that if I'm paying as credit. I called my bank and they have no idea. E mailed Samsung Pay and they don't know either. I tried uninstalling the damn program and reinstalling again and that didn't work either....
    01-20-2017 04:58 PM
  21. amyf27's Avatar
    Could it possibly have anything to do with the way the cashier rings up the sale? I had to use mine today at Walgreens and remembered I needed to get cash out for my son and was able to do so.
    01-20-2017 04:59 PM
  22. WingLT's Avatar
    No because it's happening at every store now.
    01-20-2017 05:08 PM
  23. amyf27's Avatar
    Ok. Who's your bank and is it a visa debit or a credit card like capital one etc
    01-20-2017 05:17 PM
  24. amyf27's Avatar
    I have chase bank and it's visa debit
    01-20-2017 05:18 PM
  25. mikeshauling's Avatar
    Lowes tonight, it said card read error. I tried it again and it worked just fine. The cashier asked for the last 4 digits of the card, i told her the 4 that samsung pay said to use (not the actual cards last 4 ) and it went just fine.
    Still didnt work at Applebees table reader again. Just used the actual card there at the table.
    amyf27 likes this.
    01-20-2017 10:23 PM
274 ... 891011
  1. Samsung S6 Power & Volume Buttons Broke - how to turn on?
    Last Post: 10-19-2016, 10:27 AM
  2. What samsung will do with those n7's? Will mother nature consume that garbage?
    By Mateusz Binkowski in forum Samsung Galaxy Note 7
    Last Post: 10-18-2016, 07:04 PM
  3. Replies: 1
    Last Post: 10-18-2016, 06:26 PM
  4. Replies: 0
    Last Post: 10-18-2016, 04:13 PM
  5. Car Charger Question - Can I Use The Samsung Car Charger?
    By garak0410 in forum Google Pixel & Pixel XL
    Last Post: 10-18-2016, 03:45 PM
