1. wagsgt's Avatar
    Hello all, Switched over from N7 to S7e. Anyway to get icons smaller on S7e? Side by side with N7 they are huge!
    10-18-2016 06:43 PM
  2. amyf27's Avatar
    Using nova launcher?
    parthtc09 likes this.
    10-18-2016 06:54 PM
  3. wagsgt's Avatar
    Im not familar,I will look into it. Just wondered if it was easy setting I missed, they seem so big on s7e like im 80 years old
    amyf27 likes this.
    10-18-2016 06:57 PM
  4. nndlb123's Avatar
    In settings under display there is an option for condensed. This makes the display similar to the Note 7.
    amyf27 likes this.
    10-18-2016 07:02 PM
  5. parthtc09's Avatar
    Had to put nova on mine too.
    10-18-2016 07:02 PM
  6. amyf27's Avatar
    I was wondering if they were using it. You can adjust the icon sizes quite a bit . I kind of like mine bigger and use the 5x5 grid
    10-18-2016 07:03 PM
  7. amyf27's Avatar
    Lol
    10-18-2016 07:07 PM
  8. Harry Dunn's Avatar
    Ya they get similar to the note when you make it a 5x5 grid
    10-18-2016 07:17 PM
  9. lizette1222's Avatar
    What if you long press on the home screen there should be an option for sreen grid set it to 5x5
    Harry Dunn likes this.
    10-18-2016 07:18 PM
  10. parthtc09's Avatar
    https://uploads.tapatalk-cdn.com/2016...e853f02fe2.jpg
    Yeah I prefer the customizable options, mainly being able to move the app launcher.
    10-18-2016 07:25 PM
  11. jsk0703's Avatar
    I tried this but it just didn't work to my satisfaction. I thought the icons were still too big. I ended up using Nova to get it where I was happy.
    amyf27 likes this.
    10-18-2016 09:07 PM
  12. merlinskw's Avatar
    Yeah I couldn't stand it either, had to use nova
    amyf27 likes this.
    10-18-2016 10:35 PM
  13. amyf27's Avatar
    Nova is awesome.
    merlinskw likes this.
    10-19-2016 03:43 AM
  14. Harry Dunn's Avatar
    You can also put backgrounds on the icons like the note is... It makes them smaller too
    10-19-2016 11:41 AM
  1. Remove Weather icon in Status Bar
    By coffee-turtle in forum Android 6.0 Marshmallow
    Last Post: 10-24-2016, 09:26 AM
  2. What is This Heartbeat Icon?
    By monicakm in forum Samsung Galaxy S7
    Last Post: 10-18-2016, 03:45 PM
  3. Attention all icon pack makers
    By instagib in forum Android Apps
    Last Post: 10-18-2016, 04:35 AM
  4. Replies: 1
    Last Post: 10-16-2016, 04:26 PM
  5. Attention all icon pack makers
    By instagib in forum General News & Discussion
    Last Post: 10-16-2016, 12:36 PM
