So I just turned in my N7 and went with the S7 Edge and I noticed it does not have the Samsung Cloud? I checked for updates and nothing. Anyone else have this issue? Thanks
You could try connecting your phone to a computer with Smart Switch installed to check for updates. My S7 Edge only got the Samsung Cloud option with the September update. Verizon users even have it worse with their carrier deliberately disabling Samsung cloud.
