1. prettyprincessXOXO's Avatar
    For those who may be experiencing the constant alarm clock icon on the top right of your notification bar, I just may have a few solutions for you! I personally had this problem for about 2 days on my S7 Edge with Sprint. After lots of research with not alot of answers, this what i found to be helpful and possibly to get that icon to disappear:
    1. Make sure ALL alarms are turned off/deleted in the stock clock app.
    2. Clear the cache/data in the clock app & reboot phone.
    3. Check ANY and ALL apps that have an alarm/reminder setting (i was using a birth control reminder app, and the alarm icon went off instantly after i turned the alarm/reminder off in the app). If you have these kind of apps, there's a strong chance that its triggering the alarm clock, thus making the icon appear. In this case just disable the alarm in the app or uninstall the app if you wish to remove the alarm icon.
    4. Some people said after unistalling Pandora, clock widgets/apps or various task killers, the alarm icon went away.
    Hope this helps!
    10-19-2016 09:48 PM
  2. sweetypie31's Avatar
    I have an alarm set for certain days of the week the icon only goes away if I turn off the alarm. Other than that it stays at the top of the screen . Is that not normal?
    10-20-2016 03:03 AM
  3. LeoRex's Avatar
    Its normal... if you have an alarm 'officially' registered with Android's Alarm Manager (which does more than just alarm clock type alarms by the way), that icon will persist.
    10-20-2016 09:45 AM
  1. Do not disturb till next alarm
    By ophirs in forum Samsung Galaxy S7
    Last Post: 10-20-2016, 03:38 AM
  2. Cant figure out what app this is? Status bar icon
    By johntgonzales in forum Samsung Galaxy S6
    Last Post: 10-19-2016, 02:53 PM
  3. Galaxy S7 - How long does the alarm go for?
    Last Post: 10-19-2016, 12:37 PM
  4. Icons seem huge?
    By wagsgt in forum Samsung Galaxy S7 edge
    Last Post: 10-19-2016, 11:41 AM
  5. Maybe a stupid question, but here goes.....
    By debsawyer in forum Google Home
    Last Post: 10-19-2016, 02:16 AM
