1. PJesse's Avatar
    Hello, my S7 will randomly crash. Is there anything that isn't as drastic factory reseting my phone? Any way to diagnose what's causing this?
    10-20-2016 07:29 AM
  2. B. Diddy's Avatar
    First, try wiping the cache partition, which won't erase any personal data: https://support.t-mobile.com/docs/DOC-28028
    How frequently does it crash? If it's frequent, you can also try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-28008
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    10-20-2016 07:35 AM
  3. PJesse's Avatar
    I cleared my cache partition and it seemed to temporarily fix the issue. It would crash every 5 to 10 minutes before. It hasn't crashed in the time between my first post and this one
    10-20-2016 08:31 AM
  4. PJesse's Avatar
    It's back to crashing, there is also a huge amount of lag. Funny thing is my brother and I have the same phone, and we both got the issue after the Samsung cloud/September security update. Anyone else have the same issue?
    10-20-2016 05:17 PM
  5. parthtc09's Avatar
    I had the same issue and started with wiping the cache partition. Sadly what truly fixed it for me was doing a factory reset. But in your case with lag check to see how much free storage is available, I have noticed as I fill up my phone with pictures, movies, music etc it tends to slow down a bit as I get closer to 30 gb used.
    10-21-2016 11:24 AM
  6. PJesse's Avatar
    Unfortunately even a factory reset didn't fix it, in really starting to think it's hardware failure. Considering that it effected both mine and my brothers phones at about the same time I'd think it's a manufacturing fault, I mean we've had these phones since the day after release
    10-24-2016 10:40 AM
  7. PJesse's Avatar
    Only 11gb used
    10-24-2016 10:40 AM
  1. Where is Samsung Cloud in the S7E?
    By racin06 in forum Samsung Galaxy S7 edge
    Last Post: 10-22-2016, 05:09 AM
  2. Replies: 0
    Last Post: 10-20-2016, 01:35 AM
  3. S6 EDGE freezes, then reboots randomly and sometimes solidly.
    By DanielSv in forum Samsung Galaxy S6 edge
    Last Post: 10-19-2016, 06:09 PM
  4. Samsung S7 EDGE hangs and shows random lines on the screen
    Last Post: 10-19-2016, 08:13 AM
  5. Galaxy S7 auto brightness resets randomly
    By Chris Gerber in forum Samsung Galaxy S7
    Last Post: 10-18-2016, 10:11 AM
