I've had a Ringke Fusion smoke color case for my BlackBerry Passport and it held up well for daily use for almost 2 years. Towards the last few months, the softer edges of the case started to peel away from the harder back panel. I suspect it was from using it with a holster and taking it off from time to time to clean to case and device. I also noticed, even though it was a smoke color, it did start to tinge and look dirty or a tad yellow after all that time.
For the money, it was a really great case and kept my device in great condition.
What are some of the other top clear cases, especially for the S7 Edge?
I'm looking for a case to use mostly at home or on the weekends. I'd like it to be able to hold up well after a long while, but also need it to be functional with my screen protectors. I'm currently using the Armor Suit "case friendly" screen protector and a Supcase Unicorn Beetle Pro case. It's great for when I'm at work and constantly on the move, but I'd also like a clear case that does a really great job at protecting the S7 Edge as well, for easier going days or when I get home or on the weekends.
Please list your clear case and let me know what how it's been for you. Pros, cons, best and worst.
Thanks!
Thanks!
