1. Eric Lipkind's Avatar
    I purchased some songs from the Google Play store. I downloaded them from Google Play to my phone. I can't seem to find the mp3 files anywhere. Can someone please tell me where they get saved?
    10-23-2016 01:34 PM
  2. amyf27's Avatar
    Did you go into your my files option that's a folder on one of the app pages
    10-23-2016 01:40 PM
  3. amyf27's Avatar
    Go into my files and then audio
    10-23-2016 01:41 PM
  4. lanric02's Avatar
    not there
    10-23-2016 01:47 PM
  5. keepnitreel's Avatar
    Your not going to find them and they will not show up in the Samsung music app either.
    You actually have to get on a computer and download the songs and then transfer them to your phone, if you actually want to see them.
    I bought several albums from the the play store with free credits and this is what I had to do because I use the Samsung music player
    10-23-2016 02:00 PM
  6. Eric Lipkind's Avatar
    I'll try that. Thanks.
    10-23-2016 02:41 PM
  7. amyf27's Avatar
    What music player on your phone do you use. If they're on the phone they should be accessible through the music player because it'll pull up mp3 files
    10-23-2016 03:25 PM
  8. Eric Lipkind's Avatar
    I use the Google PLAY app (or whatever the stock app is called). They do appear there. However, I want to copy one song to another device and can't locate the file.
    10-23-2016 03:39 PM
  9. amyf27's Avatar
    Do you see these options under My Files folder in your apps screen
    10-23-2016 05:54 PM
  10. Eric Lipkind's Avatar
    Yes. They are not in the audio folder.
    10-23-2016 06:25 PM
  11. amyf27's Avatar
    Do you have an SD card in there?
    10-23-2016 06:38 PM
  1. Replies: 8
    Last Post: 12-12-2017, 10:42 PM
  2. Sprint version no LG Gallery or music app?
    By BB_Bmore in forum LG V20
    Last Post: 03-14-2017, 09:36 PM
  3. I can listen to music, but I can't search for songs?
    By dyna mike in forum Samsung Galaxy S7 edge
    Last Post: 10-28-2016, 04:27 PM
  4. Location services auto turning on
    By Kalvin Kerns in forum Samsung Galaxy S6
    Last Post: 10-26-2016, 11:55 AM
  5. Google Play Music + Movies install location.
    By datafiend in forum LG V20
    Last Post: 10-23-2016, 12:02 PM
