1. ibcop's Avatar
    Okay, if this has been asked 52 times already, I apologize. On the way out the door but I wanted to pose this question.
    Maybe I was used to the Note 7 AOD but that showed everything as far as notifications. With this S7 Edge, I get nothing. Well, the clock shows but no notifications (meaning sms, gmail, etc). I'm not sure if missed calls show as I haven't had any.
    Is this normal for the S7E? I've go through everything I can think of and all apps are set to notify. I thought I read where there is going to be an update to the S7/S7E AOD but I'm not sure.
    Appreciate any input.
    10-24-2016 12:33 PM
  2. amyf27's Avatar
    Mine doesn't show emails, it just has the blue blinking dot. Waiting to see if it shows calls and texts
    10-24-2016 12:45 PM
  3. ibcop's Avatar
    Like mine. Bummer deal.
    10-24-2016 12:48 PM
  4. amyf27's Avatar
    I think mine shows unread messages. I'll have to keep an eye on it.
    10-24-2016 12:54 PM
  5. amyf27's Avatar
    Ok mine shows unread messages
    10-24-2016 01:05 PM
  6. osubass1's Avatar
    if i remember correctly, the S7 shows SMS and missed calls. it does not currently support any 3rd party apps.
    i read somewhere the plan was to update AOD to a version similar, if not identical, to the one on the Note 7 when the Nougat update gets released.
    of course, that was speculation.
    MeatLoafT likes this.
    10-24-2016 02:44 PM
  7. wookiee2cu's Avatar
    There was recently and update to AOD that added the clock option where you can add an image, I believe it was last week. Hopefully they will come out with more updates for AOD.
    10-24-2016 04:06 PM
  8. ibcop's Avatar
    So SMS through the Samsung messaging app? I use Textra so that may be the reason.
    Yeah, I have the latest then cause I have the option to add an image. Just a bummer deal it's not like the N7.
    10-24-2016 07:29 PM
  9. ibcop's Avatar
    Are you using the stock messaging app?
    10-24-2016 07:30 PM
  10. pjwk81's Avatar
    Mine shows stock SMS app and missed calls. It no longer shows from the stock email app, or how many of the other two there are.
    10-25-2016 03:49 PM
  11. oks10's Avatar
    I noticed that on this last update mine now shows what's currently playing, be it Spotify or YouTube. No control, just the title of what's playing. I also have a photo of my daughter on mine, you can actually add pictures now instead of just using the original 3 "pictures".
    Regarding notifications, i think mine shows an envelope if I have unread emails or texts. The email notification is for Nine since I have the stock email app notifications disabled.
    10-25-2016 09:20 PM
  12. chickweedblur's Avatar
    The recent update kinda ruined it I think. Like someone said it shows media that playing but with no control, missed calls and text's used to have a count, now it only displays the symbol. BTW - the Verizon Messaging app displays missed messages.
    10-26-2016 08:44 AM
  13. justin1578's Avatar
    Date, time, my custom logo, and battery.
    It will show an icon for SMS, and it will show whatever song is playing on Spotify which is really nice, but it ahows even after Ive closed the app unless I restart.
    10-26-2016 09:01 AM
  14. Abbers727's Avatar
    I think mine just tells me when I have a new text.
    10-29-2016 09:44 PM
  15. Roman Akert's Avatar
    Yes, after the initial excitement and furore of the
    Edge being upgraded to grace (and the Note AOD) it has gone very quiet indeed.
    In usual Samsung fashion we will no doubt wait some time if ever. Could be they're calling the whole 7 series a loss and concentrate instead on the 8.
    10-30-2016 10:40 AM
  1. Why does the NFC on my HTC One Mini cycle on and off?
    Last Post: 10-31-2016, 08:39 AM
  2. Does this make sense? Samsung repair?
    By Greenenvey in forum Samsung Galaxy Tab S2
    Last Post: 10-24-2016, 01:27 PM
  3. Why are there no apps showing up on phone
    Last Post: 10-24-2016, 01:12 PM
  4. Does the Battery Mod cause device to get hot?
    By mwbryant1977 in forum Moto Mods
    Last Post: 10-24-2016, 10:46 AM
  5. Replies: 1
    Last Post: 10-24-2016, 09:52 AM
