1. DroidRageYo's Avatar
    Hi all,
    I just installed the nova launcher which i love. However now it looks like I don't get numbers over messages when I receive a new message. I'm wondering if there's a way to get this back or is it gone for good? Also , does this affect other things like the edge lighting etc. I've definitely noticed that although this phone is heavily customizable , the stock functionality is very sensitive to change.
    Best,
    DRY
    10-27-2016 07:21 AM
  2. Kansatsusha's Avatar
    teslaunread....
    Im just trying to find out how to lock the nova settings though >.> without locking the whole home launcher...
    10-27-2016 07:28 AM
  3. Sam_Cohen's Avatar
    At the bottom of the settings screen there is an option for unread counts, you need to run that then it will prompt you to run another app (telsa unread (something like that). Then you will be able to choose the style etc and the apps you want the counts on.
    KPMcClave likes this.
    10-27-2016 07:30 AM
  4. DroidRageYo's Avatar
    Oh no! I think it's only for nova launcher prime
    10-27-2016 07:58 AM
  5. pwscott's Avatar
    I don't think any functionality is lost as far as I can see. Always install Nova Launcher full version and run Tesla Unread. Great combo.
    ToddK likes this.
    10-27-2016 08:00 AM
  6. chanchan05's Avatar
    Well Nova is well worth the money. Plus Tesla unread also puts number badges on apps where TouchWiz doesn't.
    10-27-2016 08:00 AM
  7. DroidRageYo's Avatar
    Yes agreed it may very well be. This launcher dwarfs the stock launcher and provides everything I could want. I did install teslaunread and it seems to allow me to change the unread counts. Thanks for the help guys!
    10-27-2016 08:05 AM
  8. DroidRageYo's Avatar
    So sadly it does not appear to be working. I installed tesla unread and enabled the settings but I don't see any counts
    10-27-2016 09:01 AM
  9. tshirttan408's Avatar
    Gestures will revolutionise your Android experience trust me
    10-27-2016 09:25 AM
  10. hawkeye680's Avatar
    Mine's working just fine with Nova and Tesla
    10-27-2016 09:33 AM
  11. DroidRageYo's Avatar
    Did you buy the full version? And also do the unread counts work when you have multiple apps in a folder?
    10-27-2016 09:36 AM
  12. B. Diddy's Avatar
    It can be a little tricky the first time. After installing TeslaUnread, open the Nova Settings app, and tap Unread Count Badges. Make sure the switch is on at the upper right, and then tap TeslaUnread Settings. Now toggle on the app icons you want badges for. Have you done all of that already?
    10-27-2016 09:37 AM
  13. KPMcClave's Avatar
    And ruin you for life. I've been using the TouchWiz launcher after a long and happy period with Nova Prime (even on this S7E initially), and I *still* try to use the pull down gesture to get to my Notifications...
    10-27-2016 09:40 AM
  14. DroidRageYo's Avatar
    Ahhh my bad I was being stingy. I just bought the full version and everything is working perfectly thanks for the help and suggestions
    B. Diddy likes this.
    10-27-2016 09:41 AM
  1. Replies: 1
    Last Post: 10-27-2016, 10:53 AM
  2. Replies: 2
    Last Post: 10-27-2016, 09:46 AM
  3. Replies: 1
    Last Post: 10-27-2016, 08:38 AM
  4. my camera not found what can ido
    Last Post: 10-27-2016, 05:37 AM
  5. Replies: 3
    Last Post: 10-27-2016, 05:03 AM
