12-01-2016 12:24 AM
27 12
  1. Joet100's Avatar
    Stock email app on GS7 Edge having typing issues. Whenever I try to type contractions like I'm it replaces the ' with " and deletes any letters after auotmatically. It also changes words like autocorrect into aautocorret and three to ttree... Autoreplace, autocaps, autospace and autopunctuate are all turned off. I talked to support twice and had someone access my device remotely. Reset my keyboard settings and the issue is still present. I was told to bring it in for service. Is there a way to fix this without wiping my device and bringing to get serviced.
    12-01-2016 12:22 AM
  2. Joet100's Avatar
    I can confirm this keyboard issue is being caused by the Android System Webview update. Force Stop and disable the update and all will be OK.
    Samsung has no clue about this when contacting their tech support staff by phone.
    12-01-2016 12:24 AM
27 12
  1. WiFi issues
    By BigRalphN in forum LG V20
    Last Post: 11-04-2016, 03:28 PM
  2. Galaxy S7 has stopped saving words I use?
    Last Post: 10-27-2016, 09:56 AM
  3. Replies: 0
    Last Post: 10-27-2016, 09:52 AM
  4. Replies: 1
    Last Post: 10-27-2016, 09:26 AM
  5. Google Fit/internal pedometer issue?
    By macarser in forum Samsung Galaxy S6 active
    Last Post: 10-27-2016, 09:25 AM
