1. Castle Rock's Avatar
    Hi, some of the phone numbers in my contacts arent saved to google. Does anyone know how you save all of the ones that are currently saved to my phone, onto google instead?
    10-28-2016 06:32 AM
  2. team420's Avatar
    Settings/accounts/google/sync contacts...
    Turn the "sync contacts" off, then back on, or just turn it on if it's already off, and it should sync to your Google account
    10-28-2016 08:19 AM
  3. chanchan05's Avatar
    When saving a contact, make sure you are setting it as a Google contact, not a device contact.
    10-28-2016 08:55 AM
  4. Shinigami Mai's Avatar
    For all the contacts stored on your phone you can export the list to a file and import them in to google from a pc browser then just make shure you select google when adding new contact.
    10-28-2016 12:21 PM
  1. Samsung S5 missimg contact sort by button.
    Last Post: 10-27-2016, 07:03 PM
  2. Replies: 0
    Last Post: 10-27-2016, 01:16 PM
  3. Issue with Contacts
    By NJ Fred in forum LG V20
    Last Post: 10-27-2016, 10:57 AM
  4. How do you stop email contacts from syncing?
    Last Post: 10-26-2016, 11:01 PM
  5. Multiple copies of contacts.
    By 103Softail in forum Ask a Question
    Last Post: 10-26-2016, 08:29 PM
