1. amyf27's Avatar
    I have that CPU heat temperature app tell me if this is unusually warm looking to you I was holding the phone on my way to work and noticed it felt kind of hot and check the temperature
    10-28-2016 08:26 AM
  2. skatergirl's Avatar
    That seems kind of warm when the phone is not doing heavy updates.
    10-28-2016 09:13 AM
  3. amyf27's Avatar
    No updates and not charging. I had Internet on, sync, etc same as usual. I also had the heat on in the van, then again I've had the heat on for several days so not that. It's cooled down since then but I could feel in through the back of my Otterbox Symmetry case
    10-28-2016 09:19 AM
  4. skatergirl's Avatar
    Definitely keep an eye on it. Maybe someone will have an idea of why it suddenly was so hot.
    10-28-2016 09:34 AM
  5. amyf27's Avatar
    Now it's at 96 degree it had gone down into the 80s and now is at 96. It's on a wireless charger at the moment.
    10-28-2016 09:43 AM
  6. T48's Avatar
    Just to clarify, which device do you have today? Note 5 or S7E? Only joking.
    Would have to imagine an app somewhere is stuck running in the background?
    10-28-2016 03:51 PM
  7. amyf27's Avatar
    Samsung had me Uninstall nova launcher for now. I don't think that was it but will see. I should be able to use what i want on the phone love it..just don't like when it's hot through the Otterbox...
    T48 likes this.
    10-28-2016 04:00 PM
  1. Where is the K Zoom successor?
    By JurijTurnsek in forum Samsung Galaxy K Zoom
    Last Post: 01-24-2017, 02:10 AM
  2. My phone says there is data but doesnt work
    Last Post: 10-28-2016, 07:39 AM
  3. can't play this video in samsung galaxy j5 prime
    Last Post: 10-28-2016, 07:35 AM
  4. Is it worth buying Lenovo Vibe Shot for $160?
    Last Post: 10-28-2016, 05:48 AM
  5. Is there any way to sync my new android to my iPad?
    Last Post: 10-28-2016, 05:42 AM
