1. hhmm's Avatar
    hi guys ,
    is really deep sleep mode not will working after rooting this device ?
    any info
    thnx
    10-28-2016 08:02 PM
  2. Rukbat's Avatar
    Rooting adds 1 file and 1 app to the phone - that's all. If you're not running an app that requires root, they just sit there doing nothing. So, yes, if the phone would have been in deep sleep mode before rooting, it will be in deep sleep mode after rooting - for the same conditions.
    hhmm likes this.
    10-29-2016 01:31 PM
  3. hhmm's Avatar
    Rukbat
    Thank you so much .
    10-29-2016 03:46 PM
  1. would you root the edge?
    By Tim Bell1 in forum Samsung Galaxy S7 edge
    Last Post: 11-27-2016, 10:24 AM
  2. Autostart app in background after reboot?
    By mwake4goten in forum Legacy Android & Other OS's
    Last Post: 10-29-2016, 05:25 PM
  3. Huge battery drop when I try to charge.
    Last Post: 10-28-2016, 05:01 PM
  4. Replies: 0
    Last Post: 10-28-2016, 03:30 PM
