1. Harelmandil's Avatar
    I bought s7 edge 4 month ago.
    Lately I have seen problems when the camera capture light.
    I upload 2 photos. One of other s7
    And the other is mine.
    What's can be the problem?
    The phone never fall of damaged.
    https://i.imgsafe.org/48e465874d.jpg
    https://i.imgsafe.org/48d8444c07.jpg
    Thanks
    10-29-2016 06:56 AM
  2. Alanhd's Avatar
    Some of the cameras came with a plastic protective cover on the lens. Have you checked yours.
    10-29-2016 08:21 AM
  3. Harelmandil's Avatar
    Thank you
    There is nothing on the lens...
    10-29-2016 09:31 AM
  4. ded1945's Avatar
    I've looked at both pictures. What exactly do you see wrong? There is an extreme contrast situation between the two lights, two windows and a low-light room. Even with that, the details and resolution on the microwave and cereal box, for example, are reasonable considering everything. What were you expecting?
    10-29-2016 10:37 AM
  5. Nakrohtap's Avatar
    Depending on where the camera is focusing, you can take 2-3 different looking pictures sitting in the same spot. I don't see the issue either. Focus on the window, everything outside is clear. Focus on something away from the window and the window will look overexposed.
    10-29-2016 12:53 PM
  1. Pixel + Pioneer AVIC-8200NEX = incompatible? Android Auto problem?
    By babouc in forum Google Pixel & Pixel XL
    Last Post: 10-11-2017, 10:29 PM
  2. Camera suddenly unavailable...
    Last Post: 11-20-2016, 05:47 AM
  3. Replies: 61
    Last Post: 11-01-2016, 03:25 PM
  4. Samsung uses two camera sensors one by them and one by Sony. I'm annoyed
    By magichoward in forum Samsung Galaxy S7 edge
    Last Post: 10-29-2016, 12:50 PM
  5. Halo Effect With Camera
    By Bartone in forum Google Pixel & Pixel XL
    Last Post: 10-28-2016, 06:52 PM
