1. amyf27's Avatar
    Is there a way to customize how you take a screenshot like programming a button to do the job. I'm currently using Nova Launcher and would like to be able to do something like that
    10-30-2016 09:21 AM
  2. B. Diddy's Avatar
    There are a number of screenshot apps on Google Play (just search there for "screenshot"): https://play.google.com/store/search...t&c=apps&hl=en. Most of them seem to require rooting in order to customize the method of taking the screenshot, but some of them might not.
    thecomicbookandme likes this.
    10-30-2016 10:40 PM
  3. Tim1954's Avatar
    Some devices will do it with a palm swipe across the screen....
    10-30-2016 10:52 PM
  4. droidtgray's Avatar
    Press the home and power button at the same time
    10-30-2016 11:09 PM
  5. pappcam's Avatar
    Since this is the S7 Edge forum, all devices will do it with a palm swipe. I believe it's enabled by default and it doesn't matter which launcher you
    re using.
    10-30-2016 11:25 PM
  6. amyf27's Avatar
    I knew about the palm swipe and the home/power button. I was curious if there was a way to make a screen shot maybe just by hitting/pressing home button twice or long pressing.
    10-31-2016 04:39 AM
  1. My phone doesn't have a hotspot option! HELP!
    Last Post: 06-05-2018, 04:19 PM
  2. Replies: 6
    Last Post: 11-01-2016, 11:27 AM
  3. Huwawei P9 - How to disable the phone lock option?
    Last Post: 10-29-2016, 10:05 AM
  4. Replies: 0
    Last Post: 10-29-2016, 03:42 AM
  5. Have I been hacked? Suspicious misspelled setting option.
    Last Post: 10-28-2016, 10:18 AM
