1. Andyvalver's Avatar
    This seems to happen with whatever android phone I have at some point during ownership. Google play services recently started keeping the device awake too much. Like 8 hours today. I don't get why. There is no need.
    I can use my phone normal with 3-4 hours of screen usage and nearly get through the day. However if I don't use the phone, say 1 hour screen time. It seems Google play services still uses up the rest of the battery. It lasts nearly the day if I don't use it much. It's almost like Google is trying to use the day of battery even if I don't use it. It's really passing me off because I have tried restarts, clear the cache and what not.
    10-30-2016 05:16 PM
  2. amyf27's Avatar
    You should be able to go into that app setting and clear it's cache
    skatergirl likes this.
    10-30-2016 05:34 PM
  3. amyf27's Avatar
    there's also a setting to put apps to sleep if its been awhile since they've been used
    10-30-2016 05:36 PM
  4. B. Diddy's Avatar
    Clearing the Google Play Services cache sometimes help, but you can't put Play Services to sleep, since it's so integral to all other Google apps.
    Lately, Google Photos has been causing some battery drain issues, that seems to have been corrected with the last couple of updates. This could be associated with Google Services keeping the phone awake. Is your Google Photos app up to date?
    10-31-2016 12:47 AM
  5. Andyvalver's Avatar
    I did clear the cache in Google play but it made no difference. I just also went and disabled Google photos because you mentioned it. I don't use that service.
    10-31-2016 02:37 AM
  6. comptechltd's Avatar
    I had an issue a week or so ago with google play throwing continuous errors. I wound up uninstalling it and reinstalling it and it fixed my issue.
    Steve
    10-31-2016 11:43 AM
  7. lammy8's Avatar
    Pretty sure there's on ongoing issue within play services whenever you update an app via mobile data it gets stuck in a wake lock. Set your play store to only update via WiFi and restart the device. Should hopefully go away
    10-31-2016 05:40 PM
  8. Andyvalver's Avatar
    This is today so far. Only used my screen for 35 mins. Play services has kept the phone awake since it came off charge. And it's been sat on a table for hours while I'm working
    11-01-2016 06:53 AM
  9. Andyvalver's Avatar
    Also found this. Location services for play services is causing high battery usage.
    11-01-2016 07:13 AM
  10. B. Diddy's Avatar
    This is not a direct solution, but do you need GPS on all the time? If you don't need precise location at all times, change the Locating Method to Wi-Fi & Mobile Networks Only. Also, tap the Improve Accuracy option, and make sure Wi-fi Scanning is turned off.
    11-01-2016 10:21 AM
  11. lammy8's Avatar
    This ^
    It'll improve your battery life a ton. Just switch on GPS when you need to use it.
    B. Diddy likes this.
    11-01-2016 07:33 PM
  12. Andyvalver's Avatar
    So I uninstalled Google play services and then reinstalled it. Put locations setting onto GPS only. So far so good...
    11-02-2016 09:25 AM
  13. B. Diddy's Avatar
    You may get better battery life by changing Location to Wi-fi/Mobile Networks Only (instead of GPS Only).
    lammy8 likes this.
    11-02-2016 10:16 AM
  14. Andyvalver's Avatar
    I'll try it. My battery is stood at 60% as I type. Not amazing still even though I sorted Google play services out. I've only had 1 and a half hours screen on time. It seems if you sort one thing another uses the power. Mainly Android OS or system.
    11-02-2016 11:15 AM
  15. lammy8's Avatar
    It's best to leave it on WiFi/mobile for general location services and only use GPS when you need to know your position more accurately (Maps for example)
    11-02-2016 06:29 PM
  16. Andyvalver's Avatar
    I'm going to try that for tomorrow. As of today my battery did OK. Here are some screen shots for anyone interested.
    11-02-2016 06:33 PM
  17. lammy8's Avatar
    https://uploads.tapatalk-cdn.com/2016...b875bb6e02.jpg
    https://uploads.tapatalk-cdn.com/2016...668430a160.jpg
    https://uploads.tapatalk-cdn.com/2016...f560e5677e.jpg
    Lots better already. Having things like GPS and the Always On Display turned off will help as will having brightness set to auto or manually set to a lower brightness.
    I'm kind of annoyed with Samsung on the latter, wish you could set a maximum value AND have it on automatic. So say if the brightest you wanted the screen was 50% it could still adjust the brightness but not go higher than 50%. They had something similar in previous galaxy devices where you could have a +/- of up to five stops and it still be able to adjust itself. Don't know why they got rid of it.
    11-02-2016 10:14 PM
  1. Screenshot with Google on Tap
    By IMANUT46 in forum Samsung Galaxy S5
    Last Post: 11-05-2016, 06:21 AM
  2. A service installation section in this INF is invalid
    Last Post: 10-31-2016, 12:53 AM
  3. Replies: 3
    Last Post: 10-31-2016, 12:06 AM
  4. Google Live Case Designs
    By RayMabry in forum Nexus 6P Accessories
    Last Post: 10-30-2016, 03:25 PM
  5. Any Nexus 6 owners use a Moto G4 Plus?
    By jeffrok in forum Google Nexus 6
    Last Post: 10-30-2016, 02:53 PM
