1. venom0706's Avatar
    I am waiting for my S7 Edge to arrive. I was wondering, should I make an initial 12 hour battery charge before first using the phone or it is fine start using it right away?
    Thank you.
    11-02-2016 04:09 AM
  2. Tim1954's Avatar
    100% should do it...
    11-02-2016 04:39 AM
  3. amyf27's Avatar
    Thank you.
    I usually start using the phone pretty much right away but it's probably a good idea to have it plugged in while its doing all the uploading of apps and related things usually the phones will arrive about 50% charged
    jbjtkbw007 likes this.
    11-02-2016 06:33 AM
  4. jbjtkbw007's Avatar
    Yeah, while you're doing your initial setup/transfer of data, have it plugged in because it will suck battery like a champ. Then, use what's left and then perform a full charge after depleting what's left.
    amyf27 likes this.
    11-02-2016 06:45 AM
  5. venom0706's Avatar
    So, a long 12-hour charge or a normal full charge after the battery has been drained out for the 1st time?
    11-02-2016 07:39 AM
  6. Almeuit's Avatar
    It's fine to start using right away and charge whenever. I usually try to not go below 30-40%. Draining it all the way isn't a good thing to do.
    thecomicbookandme likes this.
    11-02-2016 07:52 AM
  7. amyf27's Avatar
    No need for 12 hours.. It should charge up within 1 to 2 hours tops.
    11-02-2016 08:00 AM
  1. Replies: 3
    Last Post: 11-21-2017, 10:01 PM
  2. Battery mod long term life
    By heath patrick in forum Moto Mods
    Last Post: 11-17-2016, 06:40 PM
  3. LG G4 Bootlooped. What Phone Below $400 Or Less Should I Get?
    By Ronzon Fumes in forum General News & Discussion
    Last Post: 11-03-2016, 08:28 PM
  4. Google pixel xl is slow to charge
    By russo479 in forum Google Pixel & Pixel XL
    Last Post: 11-02-2016, 06:55 PM
